Controlling the looptime
Hey guys, i have a loop that i want to take 5 seconds to run.
In this loop there are a couple of variable dependent delay's.
I want to add another variable delay that precisely delays to have the loop take 5 seconds.
How can i do this?
Thanks in advance!
How can i do this?
Don't use delays at all.
unsigned long lastRunTime = 0;
   unsigned long currRunTime = millis();
   if(currRunTime - lastRunTime >= 5000)
      // Do the once every 5 seconds stuff
      lastRunTime = currRunTime;
thanks for your input
im going to give that a try.
But u think that is inside out, i dont want to do 1 thing every 5 seconds. I have a bunch of things i want in total to take 5 seconds.
SonofKingRagnar:
You will have to explain that in a lot more detail.
Do you want to slow something down so it takes a full 5 seconds?
Do you want to make sure that things all finish within 5 seconds?
Is there something that takes more than 5 seconds and you want to speed it up?
Tell us what your project is and you will get much better advice.
...R
Sure you do. You want everything that loop() currently does to be done every 5 seconds. At least, that was your initial requirement statement.
Clearly, you are changing requirements on us.
Some more details:
I have an experiment. in a fish tank i want to measure and control the pH and oxygen content. When the pH gets out of range i turn on a pump to pump acid or base. the delay i have for that is variable depending on how much the pH is out of range and the concentration of my stock solutions. The pH probe needs some time to get a new equilibrium. I could add a simple 2 sec delay but then my data collection (serial.print) has random time intervals. I want to have this complete loop to take 5 seconds to have the pH probe behave normally and have regular data points.
@Paul, Maybe I interpreted the problem/solution wrongly. It does not matter if the loop is long or short. My apologies to you for not having a good question. I do think your solution might work, it didnt yet but i did not have much time today to trouble shoot that.
@Robin, In summary I want to slow the loop down so it takes a full 5 seconds?
SonofKingRagnar:
Have a look at how millis() is used to manage timing in Several things at a time
It is perfectly possible to manage your PH measurements and your data collection with two completely separate timing schemes.
...R
  unsigned long starttime = millis();
  measure_o2();   // takes random amount of time between 0 and 1s
  measure_ph();   // takes random amount of time between 0 and 1s
  if (ph_high) {
     lower_ph();   // if ph is high, take steps to lower it.  1 to three seconds
  // Delay until the next 5s tick...
  while (millis() - starttime < 5000) {
    // spin and do nothing
Like that?
