//#include <Wire.h>
#include <ADXL345.h>
#include "FastLED.h"
ADXL345 adxl; //variable adxl is an instance of the ADXL345 library
#define NUM_LEDS 12
#define DATA_PIN 3
#define CLOCK_PIN 13
#define BRIGHTNESS 255
struct CRGB leds[NUM_LEDS];
int accuracy = 50;
int var = 1; // initial sequence
int sensitivity = 210;
int fadeIn = 20;
int fadeOut = 10;
int state = 1;
// game variables
int gameOn = 3000;
int difficulty = 10000;
// core xyz
int x, y, z;
// mapped xyz
int xa, ya, za, xb, yb, zb;
// led xyz
int xc, yc, zc, xd, yd, zd;
int fr, ba, le, ri, to, bo;
// HSV colour values
//0 red, 32 orange, 64 yellow, 96 green, 128 aqua, 160 blue, 192 purple, 224 pink, 255 red
int ledColour = 160;
int resetColour = 160;
// time variables
unsigned long previousMillisSensor = 0; // will store last time sensor was updated
const long intervalSensor = 50; // interval at which to check sensor
unsigned long previousMillisLeds = 0; // will store last time LED was updated
const long intervalLeds = 10; // interval at which to operate leds
unsigned long previousMillisBreathe = 0; // will store last time sensor was updated
const long intervalBreathe = 5000; // interval at which to check sensor
int breatheTime = 5; // inteval for inactivity in seconds
adxl.powerOn();
//set activity/ inactivity thresholds (0-255)
adxl.setActivityThreshold(75); //62.5mg per increment
adxl.setInactivityThreshold(75); //62.5mg per increment
adxl.setTimeInactivity(breatheTime); // how many seconds of no activity is inactive?
//look of activity movement on this axes - 1 == on; 0 == off
adxl.setActivityX(1);
adxl.setActivityY(1);
adxl.setActivityZ(1);
//look of inactivity movement on this axes - 1 == on; 0 == off
adxl.setInactivityX(1);
adxl.setInactivityY(1);
adxl.setInactivityZ(1);
//look of tap movement on this axes - 1 == on; 0 == off
adxl.setTapDetectionOnX(0);
adxl.setTapDetectionOnY(0);
adxl.setTapDetectionOnZ(1);
//set values for what is a tap, and what is a double tap (0-255)
adxl.setTapThreshold(50); //62.5mg per increment
adxl.setTapDuration(15); //625μs per increment
adxl.setDoubleTapLatency(80); //1.25ms per increment
adxl.setDoubleTapWindow(200); //1.25ms per increment
//set values for what is considered freefall (0-255)
adxl.setFreeFallThreshold(7); //(5 - 9) recommended - 62.5mg per increment
adxl.setFreeFallDuration(45); //(20 - 70) recommended - 5ms per increment
//setting all interupts to take place on int pin 1
//I had issues with int pin 2, was unable to reset it
adxl.setInterruptMapping( ADXL345_INT_SINGLE_TAP_BIT, ADXL345_INT1_PIN );
adxl.setInterruptMapping( ADXL345_INT_DOUBLE_TAP_BIT, ADXL345_INT1_PIN );
adxl.setInterruptMapping( ADXL345_INT_FREE_FALL_BIT, ADXL345_INT1_PIN );
adxl.setInterruptMapping( ADXL345_INT_ACTIVITY_BIT, ADXL345_INT1_PIN );
adxl.setInterruptMapping( ADXL345_INT_INACTIVITY_BIT, ADXL345_INT1_PIN );
//register interupt actions - 1 == on; 0 == off
adxl.setInterrupt( ADXL345_INT_SINGLE_TAP_BIT, 1);
adxl.setInterrupt( ADXL345_INT_DOUBLE_TAP_BIT, 1);
adxl.setInterrupt( ADXL345_INT_FREE_FALL_BIT, 1);
adxl.setInterrupt( ADXL345_INT_ACTIVITY_BIT, 1);
adxl.setInterrupt( ADXL345_INT_INACTIVITY_BIT, 1);
// Wire.begin(); // join i2c bus (address optional for master)
Serial.begin(9600); // start serial for output
delay(2000);
FastLED.addLeds<LPD8806, DATA_PIN, CLOCK_PIN, BRG>(leds, NUM_LEDS);
FastLED.clear();
FastLED.setBrightness(BRIGHTNESS);
//getInterruptSource clears all triggered actions after returning value
//so do not call again until you need to recheck for triggered actions
byte interrupts = adxl.getInterruptSource();
// adxl.readAccel(&x, &y, &z); //read the accelerometer values and store them in variables x,y,z
unsigned long currentMillisLeds = millis();
unsigned long currentMillisBreathe = millis();
if (currentMillisLeds - previousMillisLeds >= intervalLeds) {
previousMillisLeds = currentMillisLeds;
readXyz();
showLeds();
state=9;
Serial.print("**showLeds**");
// unsigned long currentMillisBreathe = millis();
// if (currentMillisBreathe - previousMillisBreathe >= intervalBreathe) {
// previousMillisBreathe = currentMillisBreathe;
if ((le==255 || ri==255 || to==255 || bo==255 || fr==255 || ba==255) && (currentMillisBreathe - previousMillisBreathe >= intervalBreathe) ) {
breatheLeds();
state=10;
Serial.print("**breaLeds**");
serialText();
} // end of timed loops
} // end of void loop
void serialText() {
Serial.print(le); Serial.print(" ");
Serial.print(ri); Serial.print(" | ");
Serial.print(ba); Serial.print(" ");
Serial.print(fr); Serial.print(" | ");
Serial.print(to); Serial.print(" ");
Serial.print(bo); Serial.print(" || ");
Serial.print(" state: "); Serial.print(state); Serial.print(" || ");
void showLeds() {
for (int i = 0; i < 2; i++) {
leds[i] = CHSV( ledColour, 255, ba); // back
leds[i+2] = CHSV( ledColour, 255, le); // left
leds[i+4] = CHSV( ledColour, 255, fr); // front
leds[i+6] = CHSV( ledColour, 255, ri); // right
leds[i+8] = CHSV( ledColour, 255, to); // top
leds[i+10] = CHSV( ledColour, 255, bo); // bottom
FastLED.show();
void breatheLeds() {
float breathe = (exp(sin(millis()/1000.0*PI)) - 0.36787944)*108.0;
leds[i] = CHSV( ledColour, 255, breathe*ba); // back
leds[i+2] = CHSV( ledColour, 255, breathe*le); // left
leds[i+4] = CHSV( ledColour, 255, breathe*fr); // front
leds[i+6] = CHSV( ledColour, 255, breathe*ri); // right
leds[i+8] = CHSV( ledColour, 255, breathe*to); // top
leds[i+10] = CHSV( ledColour, 255, breathe*bo); // bottom
FastLED.setBrightness(breathe);
FastLED.show();
void readXyz () {
xa = map(x, -255, 255, 255, 0); // left
xb = map(x, -255, 255, 0, 255); // right
ya = map(y, -255, 255, 255, 0); // front
yb = map(y, -255, 255, 0, 255); // back
za = map(z, -255, 255, 0, 255); // top
zb = map(z, -255, 255, 255, 0); // bottom
if (xa < sensitivity) le -= fadeOut; if (xa > sensitivity) le += fadeIn; if (le<0) le=0; if (le>255) le=255; state=3;
if (ya < sensitivity) fr -= fadeOut; if (ya > sensitivity) fr += fadeIn; if (fr<0) fr=0; if (fr>255) fr=255; state=4;
if (za < sensitivity) to -= fadeOut; if (za > sensitivity) to += fadeIn; if (to<0) to=0; if (to>255) to=255; state=5;
if (xb < sensitivity) ri -= fadeOut; if (xb > sensitivity) ri += fadeIn; if (ri<0) ri=0; if (ri>255) ri=255; state=6;
if (yb < sensitivity) ba -= fadeOut; if (yb > sensitivity) ba += fadeIn; if (ba<0) ba=0; if (ba>255) ba=255; state=7;
if (zb < sensitivity) bo -= fadeOut; if (zb > sensitivity) bo += fadeIn; if (bo<0) bo=0; if (bo>255) bo=255; state=8;
