Controlling two Gear motors (3V-6V) with Arduino Uno
Hi everyone.
I need to control the gear motor's velocity with muy Arduino Uno. I know Arduino can supply 5V and I think it's enough to move the motor.
I made this diagram:
My intention is just move two motors. The diagram has 4.
I connected all this things and the potientiometer works well. The screen shows the correct values but the motor doesn't work.
The transistor is bc547 b
And my code is:
int cntrl = 5;
int pot = 0;
  pinMode(cntrl, OUTPUT);
  float lvl = map(analogRead(pot), 0, 1023, 40, 255);
   analogWrite(cntrl, lvl);
  Serial.println(lvl);
Could you help me please?
Thanks :slight_smile:
  1. Bad idea to power a motor from Arduino's 5volt rail.
  2. You did not use a base current limiting resistor. Hopefully it will kill the transistor before it kills the Arduino pin.
  3. You did not use back EMF diodes across the motor.
  4. You used a tiny 100mA transistor for FOUR motors.
4x bad.
Leo..
Edit: Diagram shows the base connected to pin3. Code is pin5.
AnalogWrite can be 0-255.
Why use a float. AFAIK float won't work with map.
