So, while using board called Controllino Mini - uploading worked fine, until it suddenly stopped working. The controller itself is still running, I can access it through serial monitor through USB cable and send commands - controller is working fine. Just cant upload new program. Tried many different usb ports, com ports, baud rates etc. The same program runs fine on regular Arduino Uno.
So it hangs after the line
Description : Arduino
and then gives wrong data after
Hardware Version:
Please help me asap, as it is used in an industrial machine. Already ordered new one, but would still like to know how I bricked it and how to reset it.
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\...\arduino-1.8.6\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x00
Hardware Version: 4744608
Firmware Version: 0.4611299
Vtarget : 420030.5 V
Varef : 197193068.8 V
Oscillator : 0.531 Hz
SCK period : 17599574.7 us
avrdude: stk500_initialize(): (a) protocol error, expect=0x14, resp=0x00
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
the selected serial port
does not exist or your board is not connected
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x00
avrdude done. Thank you.
