How do you prefer to name function parameters, so that they are not confused with the variables in the calling function?
Consider this simple example:
int fnc(int val) { return ++val; }
val = fnc(val);
Two ways of handling this are:
int fnc1(int aVal) { return ++aVal; }
val = fnc1(val);
int fnc2(int _val) { return ++_val; }
val = fnc2(val);
I'm thinking of a scenario where two different calls are made to the same function. Consider this simple example:
val = fnc(val);
different_val = fnc(different_val);
This smells of inconsistency to me. Also, the scope of "val" is ambiguous.
I prefer Jimmus' approach. In the function, he used a parameter name of a more generic item than the item being passed from the calling function. That is:
No it's not. The val variable in the function is not the same as the val variable assigned by calling the function which must have been declared elsewhere. They each have their own scope. What is confusing is the use of 2 different variables with the same name. This should be familiar to you from your other thread where you had this problem.
Give variables and constants names which describe what they contain.
So func() is a silly name for an increment function. Call it increment() or incrementByOne(). Yes, I know you're only using increment as an example but that is what this function does so that is what its name must be.
print() always prints. There's lots of things it can print: strings, numbers, characters... There's lots of places it can print to, it may be Serial3.print() or LCD.print(). But its name tells you what it does.
