Hello everybody.
I have a scenario where I receive a float data from a device via MODBUS and then perform the following conversion:
uint32_t combinedValues;
float f;
node.readInputRegisters(500, 2); //Getting data from device, 2 registers.
combinedValues = (uint32_t)node.getResponseBuffer(0x00) << 16 | node.getResponseBuffer(0x01);
f = *(float*)&combinedValues; //float value here
Now I need to do it in reverse. Through a given a float value I convert to two records of the same format.
If you use a union with that data structure, you can freely write and read from either data without considering actions such as conversion.
union {
float f;
unsigned int data[2];
} combinedValues;
You can also assign each data and retrieve it with a float.
node.readInputRegisters(500, 2); // read data
combinedValues.data[1] = node.getResponseBuffer(0x00); //
combinedValues.data[0] = node.getResponseBuffer(0x01); // set with data[]
Serial.println(combinedValues.f, 5); // use with float
You can also assign with a float and retrieve each data.
combinedValues.f = 1.2345; // set with float
Serial.println(combinedValues.data[1], HEX); //
Serial.println(combinedValues.data[0], HEX); // use with data[]
EDIT: Fix endianness.
I wrote Serial.println() because I didn't know how to use the data with your program.
