Conversion from float to string question
Dear Community,
I’m trying to convert a float value called averageLux into a string.
I tried to use this function - dtostrf(FLOAT,WIDTH,PRECSISION,BUFFER);
But it doesn’t work. The string printed on the serial monitor is not correct(only display: ).
Here is the information displayed on serial monitor:
I received: 471.10 lux
471.10
0.00
0.00
0.00
0.00
I received: 476.10 lux
471.10
476.10
0.00
0.00
0.00
I received: 480.40 lux
471.10
476.10
480.40
0.00
0.00
I received: 459.30 lux
471.10
476.10
480.40
459.30
0.00
I received: 466.00 lux
471.10
476.10
480.40
459.30
466.00
Misson Completed!
Sum: 2352.90
Average Illuminance: 470.58
                                       //printed string after conversion, but only display two square symbols
Maximum Illuminance: 480.40
Minimum Illuminance: 459.30
Uniormity: 1.02
Here is the code regarding this specific question:
void AverageLux()  //Average illuminance calculation
  float sum = 0;
  for (int i=0; i<=NumOfPoints-1; i++)
    sum += LuxValue[i] ;
  averageLux = sum / NumOfPoints;
  Serial.print("Sum: ");
  Serial.println(sum);  // print average illuminance value of measurement points
  Serial.print("Average Illuminance: ");
  Serial.println(averageLux);  // print average illuminance value of measurement points
  Serial.println(dtostrf(averageLux,2,2,9));  // print average illuminance value of measurement points
Here is my full code:
#include <SPI.h>
#include <TFT.h>
#include<stdlib.h>
#define cs   10   //TFT Screen pin defintion for Arduino
#define dc   9
#define rst  8
TFT TFTscreen = TFT(cs, dc, rst);
const int NumOfPoints = 5;  // number of measurement points
char receivedChars[30];
char luxChars[5];
float LuxValue[NumOfPoints];  //measurement points
float maxLux;
float minLux;
float averageLux;
float uniformityLux;
int b = 0;    //variable for multiple measurement points - LuxValue array
  Serial1.begin(9600,SERIAL_7E1); //according to the light meter communication method
  TFTscreen.begin();
  TFTscreen.background(0, 0, 0);
  TFTscreen.setTextSize(1);
  LuxReading(); // Call LuxReading Function
  if (b == NumOfPoints)  // Calculate Average
     Serial.println(" Misson Completed!");
     TFTscreen.stroke(255, 255, 255);
     TFTscreen.text(" Misson Completed!", 40, 30);
     delay(2000);
     TFTscreen.stroke(0, 0, 0);
     AverageLux();
     MaximumLux();
     MinimumLux();
     UniformityLux();
     b = 0;
void LuxReading()  //Lux Reading Function
  int ndx = 0;  //variable for receivedChars array
  int a = 0;    //variable for luxChars array
  while (Serial1.available() > 0) //when press the D-OUT button of the light meter, read data
    char c = Serial1.read();  // store all received data into array
    if (c != '\n')
      receivedChars[ndx] = c;
      ndx++;
       Serial.print("I received: ");  // print received data on serial monitor
       for (int i=6; i<=10; i++)
         luxChars[a] = receivedChars[i];
         a++;
       LuxValue[b] = atof(luxChars);  //convert char into float and store the lux value in LuxValue Array
       Serial.print(LuxValue[b]);
       b++;
       Serial.println(" lux");  // print illuminance unit
         Serial.println(LuxValue[i]);   //print data stored in LuxValue array.The serial monitor shows the data are missing except the last one
  float sum = 0;
  delay(200);
  delay(100);
void MaximumLux()   //Maximum illuminance calculation
  maxLux = LuxValue[0];
  for (int i=1; i<=NumOfPoints-1; i++)
    maxLux = max(LuxValue[i],maxLux);
  Serial.print("Maximum Illuminance: ");
  Serial.println(maxLux);  // print Maximum Illuminance value of measurement points
void MinimumLux()   //Minimum illuminance calculation
  minLux = LuxValue[0];
    minLux = min(LuxValue[i],minLux);
  Serial.print("Minimum Illuminance: ");
  Serial.println(minLux);  // print Minimum Illuminance value of measurement points
void UniformityLux()    //Uniformity calculation
  uniformityLux = maxLux/averageLux;
  Serial.print("Uniormity: ");
  Serial.println(uniformityLux);  // print Uniformity value of measurement points
That's not how you use dtostrf(). Here's the documentation: http://www.atmel.com/webdoc/avrlibcreferencemanual/group__avr__stdlib_1ga060c998e77fb5fc0d3168b3ce8771d42.html
Yea you need to create a char buffer to put the contents into:
char buffer[16];
// The following will have a minimum of 1 digit, 2 digits after the decimal
// point, and will be dumped into the char buffer
dtostrf(averageLux, 1, 2, buffer);
Serial.println(buffer);
