Conversion from 'int' to 'const String' is ambiguous on
With the help of 2 RF24 and EMONLIB libraries, I have created the following code, I have had an error when compiling in the receiver I have a transmitter where I send a string of separated characters, I receive the data in the receiver and see it in the port serial , I want to use a conditional with the variables received and when checking it gives me an error
error: conversion from 'int' to 'const String' is ambiguous
THIS CODE RX
#include <SPI.h>
#include <RH_NRF24.h>
RH_NRF24 nrf24;
String str_datos;
String str_voltage1;
String str_voltage2;
int contactor_S = 3;
  while (!Serial);
  if (!nrf24.init())
    Serial.println("init failed");
  // Defaults after init are 2.402 GHz (channel 2), 2Mbps, 0dBm
  if (!nrf24.setChannel(1))
    Serial.println("setChannel failed");
  if (!nrf24.setRF(RH_NRF24::DataRate2Mbps, RH_NRF24::TransmitPower0dBm))
    Serial.println("setRF failed");
  Serial.println("Receptor Iniciado");
  pinMode (contactor_S, OUTPUT);
  uint8_t buf[13]; //7
  uint8_t buflen = sizeof(buf);
  if (nrf24.recv(buf, &buflen)) {
    str_datos = String ((char*)buf);
    for (int i = 0; i < str_datos.length(); i++) {
      if (str_datos.substring(i, i + 1) == ",") {
        str_voltage1 = str_datos.substring(0, i);
        str_voltage2 = str_datos.substring(i + 1);
    Serial.print("Voltage V1: ");
    Serial.println(str_voltage1);
    Serial.print("Voltage V2: ");
    Serial.println(str_voltage2);
    if ( (str_voltage1 >= 90)  &&  (str_voltage1 <= 135) ) /// ERROR!!!
      digitalWrite(contactor_S, HIGH);
what will be happening ???
try this way:
if ( (str_voltage1 >= "90") && (str_voltage1 <= "135") )
Or alternatively:
    if ( (str_voltage1.toInt() >= 90)  &&
         (str_voltage1.toInt() <= 135) )
THANK YOU , johnwasser with this alternative it works
ruilviana, thank you..
