conversion from 'int' to 'String' is ambiguous
I am sending a data packet over my arduino serial pin and receiving it on my esp8266 nodemcu RX pin.
Arduino part i coded and works fine, I declared and array and used "Serial.write(array)" command.
But on receiving the same, for my esp8266 chip, there is a compilation error.
It is an assignment error "incompatible types in assignment".
How can i read this?
Thanks in advance
Below is my code:
// Import required libraries
#include "ESP8266WiFi.h"
String msg[1000];
// WiFi parameters
const char* ssid = "lenovo";
const char* password = "password";
void setup(void)
// Start Serial
// Connect to WiFi
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
// Print the IP address
Serial.println("I am in loop, now the data part");
msg = Serial.readString();
Serial.println(msg);
An array of String with 1000 elements takes 6000 bytes of RAM, even if all the elements are empty.
Do you have 6000 bytes of RAM to spare?
msg is an array of String objects. Which element in the array are you trying to write to?
True,
Thank you,
actually i have this packet incoming
"sprintf(msg,"SMKBXX,SMCXXX,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d",....."
some 28 integers that i need to receive...
I do not understand how do i read this array "msg"
both Serial.read and Serial.readString throw me a compilation error.
How about:
String msg;
// WiFi parameters
void setup(void)
  // Start Serial
  // Connect to WiFi
    Serial.print(".");
  Serial.println("");
(uncompiled, untested - sorry, I never use Strings, unless I can't avoid them)
Yep, that takes care of the compilation part.
Thanks..!!!
Hope this string will store 28 integers for me.
sp."Hope this String will store 28 integers for me."
