Conversion from String.(substring) to float
Dear Arduino programmers,
Although the float() conversion claims that it can convert any type to float, it won't except Srting object.
Ok I can understand that, so I converted the String to a char[] type. But the float conversion still doesn't work.
(I tried *char instead of char after i got an error message telling me there is a cast incompatibility)
Bij pointing at the char I only get the firts character (5 while i should get 52 )
Can somebody help me with converting String objects into floats ?
Best regards Rob
You can use float atof(char *) from stdlib.h
#include <stdlib.h>
  Serial.println(atof("123.456"),1);
More libs see - http://www.nongnu.org/avr-libc/user-manual/modules.html -
In what code? If you have a code problem, doesn't it seem reasonable that you should post the code?
Once more, without typos, please.
I just answered this elsewhere, with code you could use:
Hope it helps.
