Conversion problem
Hello and happy good weekend :slight_smile:
I need some help for converting uint8_t to string
uint8_t mydata = DriverRxMsgData[2] ;
How can I convert mydata to string ? I searched but I dint find anything for 2 days. Please help?
Hi Aleyna
What do want to do with the string once you have it?
And what type is DriverRxMsgData[]?
Regards
Ray
Aleyna:
Can you explain where info in the DriverRxMsgData array comes from
and what it represents? And how you want the string representation to appear?
uint8_t is the same as byte or unsigned char, so might represent an 8 bit
unsigned quantity, or be packed collection of bits or the two bytes in the
array might be representing a 16 bit quantity...
DriverRxMsgData[2] is uint8_t
I want to send this data to web service. normally I can send string data to webservice succesfully. But when I try to send DriverRxMsgData[2] , I see error. This data is changing structure of data which I want to send. For example
successfull "http://www.example.com/test.ashx?test1=testdata&test2=testdata2"
when I try to send DriverRxMsgData[2] I see error, bad request, web page not found.. because
error "http://www.example.com/test.ashx?test1=testdata&test2="+DriverRxMsgData[2]
To give us an example, if the value of DriverRxMsgData[2] were 65 decimal, how would you want the URL to be?
"http://www.example.com/test.ashx?test1=testdata&test2=65"
or
"http://www.example.com/test.ashx?test1=testdata&test2=A" (65 being the ASCII code for character 'A')
Aleyna:
Clearly not, its type is uint8_t (array of byte)...
Without knowing the interpretation of those bytes its hard to know
how to proceed - what are they?
Where did they come from?
MarkT:
Aleyna:
Clearly not, its type is uint8_t (array of byte)…
It is coming from CanBus. I need to send this value to web service.
I must convert this to string and then send
So, it's binary data?
As binary data? Or as ASCII data?
That is not what the code you have posted attempts to do. That code attempts to interpret the data as a string. Not the same thing AT ALL.
