convert 2 string to a single number
what happens is that I have a code of a calculator that at the end you get two numbers, but these two numbers are string so I need if for example number1 = 1 and number2 = 4 I want to get an integer equal to 14 but I do not know how to do it, thanks.
#include <LiquidCrystal.h>
#include <Keypad.h>
#include <Wire.h>
LiquidCrystal_I2C lcd (0x27, 16, 2);
// start the code needed for keypad
const byte rows = 4;
const byte columns = 4;
byte pinsfilas [rows] = {47, 49, 51, 53}; // connect to the row pinouts of the keypad
byte pinscolumns [columns] = {39, 41, 43, 45}; // connect to the column pinouts of the keypad
boolean currentValue = false;
boolean next = false;
final boolean = false;
String number1, number2, number3;
int Total calculation;
int movement;
char operation;
float r1, r2, r3, r4;
decimal float;
int counter = 0;
char keys [rows] [columns] = {
{‘1’, ‘2’, ‘3’, ‘A’},
{‘4’, ‘5’, ‘6’, ‘B’},
{‘7’, ‘8’, ‘9’, ‘C’},
{‘E’, ‘0’, ‘F’, ‘D’}
// end the necessary keypad code
Keypad Keypad = Keypad (makeKeymap (keys), pinsfilas, pinscolumns, rows, columns);
char key;
void setup () {
Wire.begin ();
lcd.begin (16, 2);
lcd.backlight ();
lcd.setCursor (0,0);
lcd.print (“WELCOME”);
void loop () {
key = keyboard.getKey ();
int length of the number;
// I check that a certain key was pressed.
if (key! = NO_KEY && (key == ‘1’ || key == ‘2’ || key == ‘3’ || key == ‘4’ || key == ‘5’ || key = = ‘6’ || key == ‘7’ || key == ‘8’ || key == ‘9’ || key == ‘0’))
// Initialization of varaibles
if (counter == 1) {
lcd.clear ();
final = false;
number1 = “”;
number2 = “”;
Total calculation = 0;
operation = ‘’;
lcd.setCursor (0,1);
lcd.print (">");
counter = 0;
if (currentValue = true) {
number1 = number1 + key;
lengthNumber = number1.length ();
movement = lengthNumber;
lcd.setCursor (1,1);
lcd.print (number1);
number2 = number2 + key;
lengthNumber = number2.length ();
lcd.setCursor (movement + 2, 0);
lcd.print (number2);
final = true;
if (key == ‘E’)
lcd.clear ();
delay (50);
if (key == ‘A’)
lcd.clear ();
lcd.print (“Indicate cycles:”);
if (key == ‘E’)
lcd.clear ();
number2 = “”;
number1 = “”;
if (key == ‘B’)
the answer is easy, only use .intTo ()
e = number1.toInt () + number2.toInt ();
so you get if for example you have your string number1 = 1
and string number 2 = 4
and you want to get 14 and not the sum of 1 + 4 just do this
and will give you 14
@OP
1. Are you entering the numbers (digit 1 and digit 4) from a Keypad connected with the UNO?
2. Do the digits appear on the LCD side by side like?:
14
3. You think that the digits are actually being saved into two variables as character data. That is:
char x1 = 0x31;   //for 1
char x2 = 0x34;   //for 4
4. What do you want to do now? You want something like this: the contents of x1 and x2 are to be merged together to form 14 (00010100) .
5. The solution is:
byte x = x1;
x = x - 0x30;   // x = 00000001   Why is 0x30 being subtracted? Just manipulation!
x = x<<4;       // x = 00010000
byte y = x2;
y = y- 0x30;   // y = 00000100
byte z = x | y;  // z = 00010100
Serial.println(z, BIN);     //shows: 10100 ---> 00010100 (the leading 0s are not printed)
Serial.println(z, HEX);    //shows: 14
Serial.println(z, DEC);   //shows: 20
6. The alternative solution:
If you think that the entered digits are saved in character type array like this, then the solution is:
char myString[3] = {0x31, 0x34, 0x00};  //ASCII code of 1 4 NULL-byte
int z = atoi(myString);
Serial.println(z, BIN);     //shows: 1110 --> 00001110
Serial.println(z, HEX);    //shows: E
Serial.println(z, DEC);   //shows: 14
7. Compare the codes and results of Step-5 and Step-6 and then post your comments.
