Convert 3.V/5V to 1.8 V on Arduino Nano
Currently I am using optical sensor IC, which is I2C type interface. That particular IC requires 1.8V supply where I am using Arduino Nano, having 3.3V or 5V supply pins. So please tell me how I can get 1.8V supply from Arduino Nano.
Thanking You,
Best Regards,
Ajinkya Shinde
You need a voltage regulator for 1.8V, and a level shifter to connect the 1.8V I2C bus to the 3.3V or 5V I2C bus.
Hi Koepel,
Can you suggest me a level shifter IC. Also both voltage regulator and level shifter required or only level shifter is sufficient?
Best Regards,
Ajinkya
Google "I2C level shifter IC".
You need a regulator to power it and a level shifter to talk to it....
AP1117-1.8 for instance is a 1.8V regulator in the popular 1117 series
Please tell us which optical sensor it is. We like to read the datasheet. Is that optical sensor already on a module with other electronics ? Then please give a link to that module or make a photo of it.
This level shifter works with 1.8V : 4-channel I2C-safe Bi-directional Logic Level Converter [BSS138] : ID 757 : $3.95 : Adafruit Industries, Unique & fun DIY electronics and kits
A voltage regulator module for 1.8V could be this : http://www.ebay.com/itm/161811007457
This board have a voltage regulator and a level shifter: Dwukierunkowy, 8 kanałowy, konwerter poziomów logicznych – RT-NVT2008 – Robothings
