Is there a way to get a string from the serial, and then in some way to create a line of code from it to be executed on runtime ?
Or, is there any other way to get strings and "elastically" create a code lines from them?
The only way i see is to write a program that get some known strings and then call functions according to it, while this method is not elastic and requires all kinds of conversions of strings to vars, etc.
For example to get some Json or some structure over serial, then to create lines of code that will be performed live, for example somehow to turn this String "digitalWrite(1, HIGH)" , to the real command that output this.
(even not all the IDE commands, even only the basic ones )
No. The code is compiled and cannot be changed on the fly.
Not sure what you mean by elastically but you cannot enter arbitrary code to be run via Serial.
You could, as you suggest, include code in your program to parse Serial input and call functions depending on the input. Converting input to values to be used in the functions is not that difficult.
should be relatively simple, but using pin 1 would not be a good idea !
You could start with a simple interpreter that reads commands of the serial port and executes Arduino instructions like pinMode/digitalRead/digitalWrite.
Look at the Synopsis example in the documentation for the Automaton command machine which does exactly that:
gil22:
Sure.
If you want to build your own engine, then you need to capture the input character by character, identify the CR/LF, then parse. This example is terribly old and I have not updated it, but take from it what you will: Scientific Calculator
