Convert a String to int array using Arduino Nano328
Hi to all,
I’ve this problem.
My scenario is:
I receive a message bye Serial channel, this message is very long, for example is a String of 308 chars.
This message is composed by several integer, example “123,500,4500,2340…”
I need to convert this string in array of int.
In my example I declared the message valued (I simulate that I reveied it by serial)
  prog_uchar message[] PROGMEM = "350,165,50,35,50,120,50,35,50,40,50,35,50,35,50,35,50,35,50,35,50,40,45,40,50,35,50,35,50,120,50,35,50,40,50,35,50,35,50,35,50,35,50,35,50,40,45,40,50,120,50,35,50,35,50,35,50,40,50,35,50,35,50,35,50,35,55,30,50,40,45,125,50,35,50,120,50,125,45,40,50,35,50,35,50,35,50,120,50,40,50,120,50,120,50,35,55,120,50";
  int len = 308;
  unsigned int messageRaw[99];
  int i = 0;
  char c;
  while(i < len)
    char currentStr;
    byte single = pgm_read_byte_near(message + i);
    currentStr = single;
    Serial.print("Current char: ");
    Serial.println(currentStr);
    if(currentStr != ',')
      count += 1;
      current.concat(currentStr);
      Serial.print("Number to convert: ");
      Serial.println(current);
      char currentValue[] = "";
      current.toCharArray(currentValue,count+1);
      messageRaw[index] = atoi(currentValue);
      Serial.print("Converted value: ");
      Serial.println(messageRaw[index]);
      index += 1;
      count = 0;
      current = "";
    i++;
My problem is that into monitor of ide, I read wrong character! It appears alla wrong characters.
I’m sure that I wrong somethings but I don’t konw what!
Can you help me?
Your code does not compile:
sketch_oct04e.ino: In function ‘void loop()’:
sketch_oct04e:23: error: ‘count’ was not declared in this scope
sketch_oct04e:24: error: ‘current’ was not declared in this scope
sketch_oct04e:29: error: ‘current’ was not declared in this scope
sketch_oct04e:32: error: ‘count’ was not declared in this scope
sketch_oct04e:33: error: ‘index’ was not declared in this scope
http://snippets-r-us.com/
Sorry!
int count = 0;
String current = "";
int index = 0;
boolean first = true;
But I finally solved!
I changed this row byte single = pgm_read_byte_near(message + i); in byte single = message;
But now I need more help! I need to another step before this row prog_uchar message[] PROGMEM = "...."
I need to assing a String to this prog_uchar message[]
Howe can I do it?
You most certainly do NOT. The String class is a waste of resources. Learn to use C-style strings (NULL terminated arrays of chars) instead.
If you wish to use String class, read the reference on String.reserve() function. If you want to do it using the c-string, then best approach is to write a state machine. It will take in one char at a time and processes it according to its state.
