Hi!
I'm looking for some help in modifying code for a "headtracker", used to track your head movements to control RC drones. I need to get the data into the program SuperCollider, which takes 16 bit integer, while the code currently spits out floats.
I obviously want to keep as much precision in the data as possible, but I'm unsure how or where would be the best place in the code to intervene.
Here is the full code:
https://code.google.com/archive/p/open-headtracker/downloads
This is the function that outputs the values in the end:
void trackerOutput()
Serial.print(tiltAngleLP - tiltStart + 90);
Serial.print(",");
Serial.print(rollAngleLP - rollStart + 90);
Serial.print(",");
Serial.println(panAngleLP + 180);
And this is a function before it which calculates filters to smooth out the values:
// Func: Filter
// Desc: Filters / merges sensor data.
void FilterSensorData()
int temp = 0;
// Used to set initial values.
if (resetValues == 1)
#if FATSHARK_HT_MODULE
digitalWrite(BUZZER, HIGH);
#endif
resetValues = 0;
tiltStart = 0;
panStart = 0;
rollStart = 0;
UpdateSensors();
GyroCalc();
AccelCalc();
MagCalc();
panAngle = 0;
tiltStart = accAngle[0];
panStart = magAngle[2];
rollStart = accAngle[1];
digitalWrite(BUZZER, LOW);
#endif
// Simple FilterSensorData, uses mainly gyro-data, but uses accelerometer to compensate for drift
rollAngle = (rollAngle + ((gyroRaw[0] - gyroOff[0]) * cos((tiltAngle - 90) / 57.3) + (gyroRaw[2] - gyroOff[2]) * sin((tiltAngle - 90) / 57.3)) / (SAMPLERATE * SCALING_FACTOR)) * gyroWeightTiltRoll + accAngle[1] * (1 - gyroWeightTiltRoll);
tiltAngle = (tiltAngle + ((gyroRaw[1] - gyroOff[1]) * cos((rollAngle - 90) / 57.3) + (gyroRaw[2] - gyroOff[2]) * sin((rollAngle - 90) / 57.3) * -1) / (SAMPLERATE * SCALING_FACTOR)) * gyroWeightTiltRoll + accAngle[0] * (1 - gyroWeightTiltRoll);
panAngle = (panAngle + ((gyroRaw[2] - gyroOff[2]) * cos((tiltAngle - 90) / 57.3) + (((gyroRaw[0] - gyroOff[0]) * -1) * (sin((tiltAngle - 90) / 57.3)) ) + ( ((gyroRaw[1] - gyroOff[1]) * 1) * (sin((rollAngle - 90) / 57.3)))) / (SAMPLERATE * SCALING_FACTOR)) * GyroWeightPan + magAngle[2] * (1 - GyroWeightPan);
if (TrackerStarted)
// All low-pass filters
tiltAngleLP = tiltAngle * tiltRollBeta + (1 - tiltRollBeta) * lastTiltAngle;
lastTiltAngle = tiltAngleLP;
rollAngleLP = rollAngle * tiltRollBeta + (1 - tiltRollBeta) * lastRollAngle;
lastRollAngle = rollAngleLP;
panAngleLP = panAngle * panBeta + (1 - panBeta) * lastPanAngle;
lastPanAngle = panAngleLP;
float panAngleTemp = panAngleLP * panInverse * panFactor;
if ( (panAngleTemp > -panMinPulse) && (panAngleTemp < panMaxPulse) )
temp = servoPanCenter + panAngleTemp;
channel_value[htChannels[0]] = (int)temp;
float tiltAngleTemp = (tiltAngleLP - tiltStart) * tiltInverse * tiltFactor;
if ( (tiltAngleTemp > -tiltMinPulse) && (tiltAngleTemp < tiltMaxPulse) )
temp = servoTiltCenter + tiltAngleTemp;
channel_value[htChannels[1]] = temp;
float rollAngleTemp = (rollAngleLP - rollStart) * rollInverse * rollFactor;
if ( (rollAngleTemp > -rollMinPulse) && (rollAngleTemp < rollMaxPulse) )
temp = servoRollCenter + rollAngleTemp;
channel_value[htChannels[2]] = temp;
