Convert an Excel Calculation to Arduino
Hello, I am curve fitting a thermal couple using Excel.
This Excel calculation for “=14.782578+0.099628456*P31^1.4634484” calculates the correct answer of 29.95008781 of 31 degrees F.
Where” P31” = 31 or the variable in the code below called "Outside".
The form of the equation is Y = A + B X^C from TableCurve (curve fitting software).
I programmed this into Arduino and the results of 21.77 are wrong.
Please check out a copy of my code below:
double A = 14.782578; double B = .09962846; double C = 1.4364484; Outside = A + B * Outside * sqrt(C);
Thanks, Lou
What operation do you think the "^" symbol performs?
Which C/C++ function performs that operation?
double B = 0.09962846;
double Outside = 31.0;
    while(!Serial);
    Outside =  A + (B * pow(Outside, C));
    Serial.println(Outside,7);
gives 28.6070176 at the serial output which is the same result I get when I use my calculator.
You sure about your "correct" answer?
Hi, What thermocouple or thermistor are you using?
Thanks.. Tom.. :)
Try this...
Outside = A + B * pow (Outside,C);
I got it from here:
https://www.arduino.cc/reference/en/language/functions/math/pow/
pow() [Math] Description Calculates the value of a number raised to a power. Pow() can be used to raise a number to a fractional power. This is useful for generating exponential mapping of values or curves.
Syntax pow(base, exponent)
Parameters base: the number (float)
exponent: the power to which the base is raised (float)
Returns The result of the exponentiation. (double)
