Convert array of characters into array of their binary values
I’m trying to turn the array “hello”, with the DEC values of the characters used being: 56, 53, 60, 60, 63 and the array I’m trying to therefore obtain is: “0110100001100101011011000110110001101111” (the values of each character has 8 bits, starting with 0).
What I have written so far is:
  int v[256];
  char c[] = "hello";
  int ascii_dec, int = 0, k = 0, j = 0;
  while (c[i] != '\0') {
    ascii_dec = c[i] - '0';
    Serial.println(ascii_dec);
    v[k] = 0;
    ++k;
    for (j = 7; j > 0; j--) {
      v[k] = bitRead(ascii_dec, j);
      Serial.print(" Bit is: ");
      Serial.print(v[k]);
      Serial.print(" and k is: ");
      Serial.print(k);
      Serial.print(" ---- ");
      ++k;
    Serial.print("\n");
    ++i;
  for (i = 0; i < 40; i++) {
    Serial.print(v[i]);
I have assumed that each value is represented on 7 bits.
The output is (I have ommited printing the first ‘0’ I’m trying to add in order to obtain the value on 8 bits):
56
Bit is: 0 and k is: 1 ---- Bit is: 0 and k is: 2 ---- Bit is: 1 and k is: 3 ---- Bit is: 1 and k is: 4 ---- Bit is: 1 and k is: 5 ---- Bit is: 0 and k is: 6 ---- Bit is: 0 and k is: 7 ----
53
Bit is: 0 and k is: 9 ---- Bit is: 0 and k is: 10 ---- Bit is: 1 and k is: 11 ---- Bit is: 1 and k is: 12 ---- Bit is: 0 and k is: 13 ---- Bit is: 1 and k is: 14 ---- Bit is: 0 and k is: 15 ----
60
Bit is: 0 and k is: 17 ---- Bit is: 0 and k is: 18 ---- Bit is: 1 and k is: 19 ---- Bit is: 1 and k is: 20 ---- Bit is: 1 and k is: 21 ---- Bit is: 1 and k is: 22 ---- Bit is: 0 and k is: 23 ----
60
Bit is: 0 and k is: 25 ---- Bit is: 0 and k is: 26 ---- Bit is: 1 and k is: 27 ---- Bit is: 1 and k is: 28 ---- Bit is: 1 and k is: 29 ---- Bit is: 1 and k is: 30 ---- Bit is: 0 and k is: 31 ----
63
Bit is: 0 and k is: 33 ---- Bit is: 0 and k is: 34 ---- Bit is: 1 and k is: 35 ---- Bit is: 1 and k is: 36 ---- Bit is: 1 and k is: 37 ---- Bit is: 1 and k is: 38 ---- Bit is: 1 and k is: 39 ----
0001110000011010000111100001111000011111
So… it doesn’t seem to do what I’m trying to. Does anyone have any idea why?
Serial.print (x, BIN); ?
I'm not really clear what you're getting at - they're already in an array of their binary values.
Why the adjustment for the character zero:
probably should be:
    ascii_dec = c[i];
laoonatic:
Each byte constists of 8 bits. If you write the byte in binary, this might be:
byte x=0b00001011;
The leftmost bit is called the 7th bit, and from left to right the bit numbering is:
bit-7, bit-6, bit-5, bit-4, bit-3, bit-2, bit-1, bit-0
bit-0 stands for 20 = 1
bit-1 stands for 21 = 2
bit-2 stands for 22 = 4
bit-3 stands for 23 = 8
bit-4 stands for 24 = 16
bit-5 stands for 25 = 32
bit-6 stands for 26 = 64
bit-7 stands for 27 = 128
So 0b00001011
== 123 + 022 + 121 + 120
== 8 + 0 + 2 + 1
== 9;
So the number with value 9 (decimal) is just the same as 0b00001011 (binary).
For the controller 9 and 0b00001011 are absolutely the same - no difference!
They are not different numbers, its just a different visual representation of a number.
Is there any special reason why you want to convert the bit encoded “hello” array to a much bigger char array of ASCII-Codes “0110100001100101011011000110110001101111”?
If you want to do so, you could access any bit in the “hello” string using the bitRead() macro.
Example code:
  char str[]="hello";
  Serial.print(str);
  Serial.println(" converts to ");
  for (int i=0;i<strlen(str);i++)  // loop through all chars in string (from 'h' to 'o')
    for (int j=7;j>=0;j--) // loop from bit-7 down to bit-0 (high-bit to low-bit)
      Serial.print(bitRead(str[i],j)); // from str[i] read the bit-j and print it
void loop() {}
@econjack Thank you, that was indeed the problem!
@AWOL I know I can print their values like this, but I needed them stored in a vector.
@jurs I know that a byte consists of 8 bits, but the ASCII codes can be stored on 7 bits. Now I see that I overlooked the fact that I could read the bits starting from 8 and it would basically be the same. Probably because when you print a letter in BIN it gives you only 7 bits and that got stuck in my mind. And yes, there is a reason, I want to calculate a checksum for these bits. Also, I do not want to convert the bit encoded char array into another char array, but into an array of integers.
Thank you all for your answers!
I have changed my code to this:
    for (j = 8; j > 0; j--) {
      v[k] = bitRead(c[i], j);
      Serial.print(v[k]);
      Serial.print(k);
      k++;
    Serial.print("\n");
    i++;
    Serial.print(v[i]);
  // check:
  Serial.print("\n");
  i = 0;
    Serial.print(c[i], BIN);
    i++;
I added the last part in order to check my output, and the not-so-funny thing is that the outputs differ like this.
Array computed with bitRead vs. Serial.print with argument BIN (in fact there were groups of 7 bits, I added one 0 in front of them to make out the difference)
0011010000110010001101100011011000110111
The array has an additional “0” at the beginning, lacks “1” in the end and has the 16th bit wrong and I have no idea why.
Bit read numbers the bits 0 through 7, not 1 through 8.
It's the same thing, actually :) Whether you go from 0 (inclusive) to 7, or from 0 (exclusive) to 8 you get 8 steps.
Edit: No, it's not. My bad. I forgot that I was printing bits, not just counting steps. Thank you!
laoonatic: The array has an additional "0" at the beginning, lacks "1" in the end and has the 16th bit wrong and I have no idea why.
Perhaps you'd read my last posting once more.
A byte has 8 bits, the bit numbers go from bit-7 to bit-0 And that's what the bit index counts from left to right: 7 down to 0.
And you are doing:
There is no bit-8 in a byte as bit-7 already is the 8th bit.
laoonatic: It's the same thing, actually :) Whether you go from 0 (inclusive) to 7, or from 0 (exclusive) to 8 you get 8 steps.
Except it's not the same thing because when you call bitread( 8 ) your index is out of bounds. It looks for the ninth bit in the byte and that just isn't there. Sure it is still 8 steps, but you miss one bit, pick up an extra bit that isn't there, and get the last one wrong. Wasn't that your complaint in post 5?
I was editing my post, you're right, I noticed right now. As I was saying in the edit, I forgot that I was printing bits, not just counting steps. Silly. Thank you!
