Convert AVR sketch to ESP32
I need to use an ESP32 with this sketch that was written for AVR devices. What can I study up on and learn in order to get this working with the ESP32.
I get compilation errors related to the registers ("// Set stepper interrupt" section)
Will I just need to switch the registers to ones that the ESP32 uses?
Any guidance is extremely appreciated. Thank you
byte MAX_SPEED = 10; // In timer value
byte MIN_SPEED = 400;
byte STALL_VALUE = 14; // [-64..63]
// Note: You also have to connect GND, 5V and VM.
//       A connection diagram can be found in the schematics.
const int EN_PIN = 10;
const int DIR_PIN = 21;
const int STEP_PIN = 22;
const int CS_PIN = 19;
const int MOSI_PIN = 5; //SDI/MOSI
const int MISO_PIN = 23; //SDO/MISO
const int SCK_PIN  = 18; //CLK/SCK
#include <SPI.h>
#include <TMC2130Stepper.h>
#include <TMC2130Stepper_REGDEFS.h>
TMC2130Stepper driver = TMC2130Stepper(EN_PIN, DIR_PIN, STEP_PIN, CS_PIN);
bool vsense;
uint16_t rms_current(uint8_t CS, float Rsense = 0.11) {
  return (float)(CS+1)/32.0 * (vsense?0.180:0.325)/(Rsense+0.02) / 1.41421 * 1000;
  //init serial port
    Serial.begin(250000); //init serial port and set baudrate
    while(!Serial); //wait for serial port to connect (needed for Leonardo only)
    Serial.println("\nStart...");
    driver.begin();
  //set TMC2130 config
    driver.rms_current(1000); // mA
    driver.microsteps(1);
    driver.diag1_stall(1);
    driver.diag1_active_high(1);
    driver.coolstep_min_speed(0xFFFFF); // 20bit max
    driver.THIGH(0);
    driver.semin(5);
    driver.semax(2);
    driver.sedn(0b01);
    driver.sg_stall_value(STALL_VALUE);
    cli();//stop interrupts
    TCCR1A = 0;// set entire TCCR1A register to 0
    TCCR1B = 0;// same for TCCR1B
    TCNT1  = 0;//initialize counter value to 0
    OCR1A = 60;// = (16*10^6) / (1*1024) - 1 (must be <65536)
    // turn on CTC mode
    TCCR1B |= (1 << WGM12);
    // Set CS11 bits for 8 prescaler
    TCCR1B |= (1 << CS11);// | (1 << CS10);
    // enable timer compare interrupt
    TIMSK1 |= (1 << OCIE1A);
    sei();//allow interrupts
  //TMC2130 outputs on (LOW active)
  digitalWrite(EN_PIN, LOW);
  vsense = driver.vsense();
ISR(TIMER1_COMPA_vect){
  digitalWrite(STEP_PIN, HIGH);
  digitalWrite(STEP_PIN, LOW);
  static uint32_t last_time=0;
  uint32_t ms = millis();
  while(Serial.available() > 0) {
    int8_t read_byte = Serial.read();
    if (read_byte == '0')      { TIMSK1 &= ~(1 << OCIE1A); digitalWrite( EN_PIN, HIGH ); }
    else if (read_byte == '1') { TIMSK1 |=  (1 << OCIE1A); digitalWrite( EN_PIN,  LOW ); }
    else if (read_byte == '+') if (OCR1A > MAX_SPEED) OCR1A -= 20;
    else if (read_byte == '-') if (OCR1A < MIN_SPEED) OCR1A += 20;
  if((ms-last_time) > 100) //run every 0.1s
    last_time = ms;
    uint32_t drv_status = driver.DRV_STATUS();
    Serial.print("0 ");
    Serial.print((drv_status & SG_RESULT_bm)>>SG_RESULT_bp , DEC);
    Serial.print(" ");
    Serial.println(rms_current((drv_status & CS_ACTUAL_bm)>>CS_ACTUAL_bp), DEC);
Your code is configuring the built-in timer 1 registers on the AVR chip.
    // turn on CTC mode
There are a number of registers per timer. Two of these registers –the Timer/Counter Control Registers- hold setup values, and are called TCCRxA and TCCRxB, where x is the timer number (TCCR1A and TCCR1B, etc.). Each register holds 8 bits, and each bit stores a configuration value.
The ESP32 chip contains two hardware timer groups, each containing two general-purpose hardware timers. They are all 64-bit generic timers based on 16-bit prescalers and 64-bit auto-reload-capable up/down counters.
You need to study How timers work in both cases and replace the code to use ESP32 timers
