I'm using an Arduino to grab some measurements from our electric meter via Modbus.
Measurements are stored as 32 bit IEEE 754 floats and split up into two registers (16 bits each). If I read two consecutive registers, I obtain the values, e.g.:
#1: 100001001001000 #2: 1010001111011
If I concatenate these and want to print it, the result is wrong. I figured out that I have to add leading zeroes to them until they are 16 bits long each:
without zeroes: 100001001001000 1010001111011 = 1.9341583E-36
with zeroes : 0100001001001000 0001010001111011 = 50,02 (Hz)
I wrote a function that adds the missing zeroes, but I don't know how to convert this "binary float string" into a readable number that I can save in a database.
I can't give useful code examples. I only fetch two registers via Modbus (Library: ArduinoModbus.h) and prepend missing zeros. Nothing else.
The manual is not available online and the only specification given is that it uses "Floating point as per IEEE Standard".
But if I plug in the 32 bit long binary number into this converter (IEEE-754 Floating Point Converter) the correct result appears (I can read on the power meter, that the frequency is ~50 Hz and that's the measurement I'm currently trying to retrieve).
I tried some casting, but this results in "2.07"...
unsigned long i = 01000010010010000001010001111011;
float f = *(float*)&i;
Still not enough info. The solution will likely involve memcpy(). But, to get it right, you need to know how it comes in and how it's stored in your variables. Understand that a uint32_t will be stored in Little Endian format in the Arduino.
Your endianess is wrong.
int val1 = 0b100001001001000;
int val2 = 0b1010001111011;
uint32_t data = (uint32_t)val1 << 16 | val2;
float f = *(float*)&data;
Serial.println(f);
Ok, here's the full code. It's more of a doodle, than actual code.
I was reading the same measurement from two different locations, because one is given as an Integer (start: 0x0040, length: 1) and the other in IEEE (start: 0x1038, length: 2). I did it because I wanted to know, how to read a value from two registers, because the output was not what I was expecting it to be. Therefore I did this comparison.
Then I tried dealing with the binary numbers, added leading zeroes and tried to convert it to a readable number again. That's why I'm playing with variables reg1 and reg2 instead of using real-world values directly from ModbusRTUClient.read().
#include <ArduinoRS485.h>
#include <ArduinoModbus.h>
String addLeadZeroes(String binInput) {
int len = binInput.length();
int neededZeroes = 16 - len;
String leadZeroes = "";
for(int i = 0; i < neededZeroes; i++) {
leadZeroes += "0";
leadZeroes += binInput;
return leadZeroes;
Serial.begin(19200);
while (!Serial);
String reg1 = "100001001001000";
String reg2 = "1010001111011";
String zReg1 = addLeadZeroes(reg1);
String zReg2 = addLeadZeroes(reg2);
String final = zReg1 + zReg2;
Serial.println(final);
Serial.println("Modbus");
// start the Modbus RTU client
if (!ModbusRTUClient.begin(19200)) {
Serial.println("Failed to start Modbus RTU Client!");
while (1);
Serial.println("Success");
// Read from Registers with type "Integer" (given from manual)
if (!ModbusRTUClient.requestFrom(1, INPUT_REGISTERS, 0x0040, 1)) {
Serial.print("failed to read registers! ");
Serial.println(ModbusRTUClient.lastError());
while(ModbusRTUClient.available()) {
Serial.println(ModbusRTUClient.read(), DEC);
Serial.println("----");
// Read from Registers with type "IEEE" (given from manual)
if (!ModbusRTUClient.requestFrom(1, INPUT_REGISTERS, 0x1038, 2)) {
Serial.println(ModbusRTUClient.read(), BIN);
delay(5000);
Both of your solutions are working! Thanks alot! Now I just have to rewrite it, so that it's converting the data from ModbustRTUClient.read().
Hi
Would it not be easier to just declare a 2 byte array. Get your data from modbus RTU in the byte array and then store the byte array in your high level environment? There you can have much easier options to convert the byte array to float values you need. If you are not consuming floats on Arduino then why bother converting it on Arduino?
Even without having known the full codes of your sketch, it is possible to know (from the following information of IEEE-754 Structure) the clues of inserting leading zeros with the register values.
1. IEEE-754 Format for 32-bit Floating Point Number
Figure-1:
2. Figure-1 demands that the input binary data should be a 32-bit number and must align with it.
3. Your numbers are: (1) Higher 16-bit:
100001001001000
==>0100001001001000
