Hi
RejsaRubberTrac is a project, that shows realtime tiretemperature in Harrys Lap Timer.
I try to "convert" the BLE Gatt Profile from Rejsa project, which is realized with the bluefruit.h lib in the ESP32 BLE lib. I digged in in the subject 2 days but dont manage to get it to work....
The code from Rejsa project should work out of the box with Harrys lap timer, because the two libs work so different i need a BLE pro to help me. all the code related to get the data from IR-cam, battery Status and so on does not mather, i can handle that, but i would like to have harrys laptimer to detect my M5-stick-c.
I dont know which are the key values to match, for working with harrys lap timer. for example, in rejsa i dont found UUIDs. I tested my code with the nRF-Connect app on android, and somehow it broadcasts values and work in some way but in the laptimer app it doesnt
This is my code :
[color=#c586c0]#include <BLEDevice.h>
#include <BLEServer.h>
#include <BLEUtils.h>
#include <BLE2902.h>
#include <M5StickC.h>
BLEServer *pServer = NULL;
BLECharacteristic *pCharacteristic = NULL;
BLECharacteristic *pCharacteristic1 = NULL;
BLECharacteristic *pCharacteristic2 = NULL;
bool deviceConnected = false;
bool oldDeviceConnected = false;
uint32_t value = 0;
// See the following for generating UUIDs:
// https://www.uuidgenerator.net/
#define SERVICE_UUID "4fafc201-1fb5-459e-8fcc-c5c9c331914b"
#define CHARACTERISTIC_UUID "beb5483e-36e1-4688-b7f5-ea07361b26a8"
#define PROTOCOL 0x02
class MyServerCallbacks : public BLEServerCallbacks
void onConnect(BLEServer *pServer)
deviceConnected = true;
void onDisconnect(BLEServer *pServer)
typedef struct {
uint8_t protocol; // version of protocol used
uint8_t unused;
int16_t distance; // millimeters
int16_t temps[8]; // all even numbered temp spots (degrees Celsius x 10)
} one_t;
typedef struct {
uint8_t charge; // percent: 0-100
uint16_t voltage; // millivolts (normally circa 3500-4200)
int16_t temps[8]; // all uneven numbered temp spots (degrees Celsius x 10)
} two_t;
typedef struct {
uint8_t unused;
int16_t temps[8]; // All 16 temp spots used as pairs of two each, max from each pair goes into these 8 temp values (degrees Celsius x 10)
} thr_t;
one_t datapackOne;
two_t datapackTwo;
thr_t datapackThr;
M5.begin();
M5.Lcd.print("Hallo Gigu");
// Create the BLE Device
BLEDevice::init("RejsaRubber6412051B");
// Create the BLE Server
pServer = BLEDevice::createServer();
pServer->setCallbacks(new MyServerCallbacks());
// Create the BLE Service
BLEService *pService = pServer->createService(SERVICE_UUID);
// Create a BLE Characteristic
pCharacteristic = pService->createCharacteristic(
CHARACTERISTIC_UUID,
BLECharacteristic::PROPERTY_READ |
BLECharacteristic::PROPERTY_NOTIFY);
pCharacteristic1 = pService->createCharacteristic(
pCharacteristic2 = pService->createCharacteristic(
// SET SOME DEFAULT VALUES IN THE DATA PACKETS
datapackOne.distance = 0;
datapackOne.protocol = PROTOCOL;
datapackTwo.protocol = PROTOCOL;
datapackThr.distance = 0;
datapackThr.protocol = PROTOCOL;
// https://www.bluetooth.com/specifications/gatt/viewer?attributeXmlFile=org.bluetooth.descriptor.gatt.client_characteristic_configuration.xml
// Create a BLE Descriptor
pCharacteristic->addDescriptor(new BLE2902());
pCharacteristic1->addDescriptor(new BLE2902());
pCharacteristic2->addDescriptor(new BLE2902());
// Start the service
pService->start();
// Start advertising
BLEAdvertising *pAdvertising = BLEDevice::getAdvertising();
pAdvertising->addServiceUUID(SERVICE_UUID);
pAdvertising->setScanResponse(true);
pAdvertising->setMinPreferred(0x0); // set value to 0x00 to not advertise this parameter
BLEDevice::startAdvertising();
Serial.println("Waiting a client connection to notify...");
// notify changed value
if (deviceConnected)
pCharacteristic->setValue((uint8_t *)&datapackOne, sizeof(datapackOne));
pCharacteristic->notify();
pCharacteristic1->setValue((uint8_t *)&datapackTwo, sizeof(datapackTwo));
pCharacteristic1->notify();
pCharacteristic2->setValue((uint8_t *)&datapackThr, sizeof(datapackThr));
pCharacteristic2->notify();
value++;
delay(500); // bluetooth stack will go into congestion, if too many packets are sent, in 6 hours test i was able to go as low as 3ms
// disconnecting
if (!deviceConnected && oldDeviceConnected)
delay(500); // give the bluetooth stack the chance to get things ready
pServer->startAdvertising(); // restart advertising
Serial.println("start advertising");
oldDeviceConnected = deviceConnected;
// connecting
if (deviceConnected && !oldDeviceConnected)
// do stuff here on connecting
}[/color]
