Hi
I am trying to convert a byte returned from a ADG2188 analogue cross point switch, so i have the byte 0x10 this represents closed switches between input and output.
this chip is a 8 x 8 matrix of switches and i wish to represent this matrix on a web page.
if i switched on y2 and y3 to x0 then when i queried the status of x0 i would receive back the byte 0x10 representing the binary number 00001100, which if i could use this binary number this would represent nicely the x0 line 8 x 8 matrix connections.
would anyone be able to tell me how i might go about achieving this?
thanks
Simon
have you tried bitRead()?
You could come up with a simple function in your program that does that. It could, for example, receive a byte value, look up the equivalent bits in a switch statement, and do the conversion. This is especially useful if you are using relatively small values.
well i have had a look at bitRead but am a bit lost can i do the below?
// Arrays
byte myCPArray[8] = {0x34, 0x3C, 0x74, 0x7C, 0x35, 0x3D, 0x75, 0x7D};
byte mySwitchStatus [8] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
int myXOPArray[8][8];
for (int k = 0; k < 8; k++);
for (int l = 0; l < 8; l++);
myXOPArray[k][ bitRead(myCPArray[k],l)];
i am getting the below compile errors
sketch_dec01a.ino: In function 'void loop()':
sketch_dec01a.ino:211:25: error: name lookup of 'k' changed for ISO 'for' scoping [-fpermissive]
sketch_dec01a.ino:211:25: note: (if you use '-fpermissive' G++ will accept your code)
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI/SPI.h:16:0,
from sketch_dec01a.ino:14:
sketch_dec01a.ino:211:50: error: name lookup of 'l' changed for ISO 'for' scoping [-fpermissive]
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:103:43: note: in definition of macro 'bitRead'
#define bitRead(value, bit) (((value) >> (bit)) & 0x01)
Error compiling.
thanks for any help you can give
One thing that would help is not having the semicolons on the end of the for lines....
Lol, isn't it amazing, i just could not see those for looking!! i was pulling my hair out trying to find that issue
thank you so much
Simon
Now you just have to make the program do what you intended.
may be syntactically correct but does it actually do anything ?
Nope it does not!! so i added some debug
Serial.print ("Output X");
Serial.print (k);
Serial.print (" ");
Serial.print ("Position ");
Serial.print (l);
Serial.print (" ");
Serial.print ("Data in Array ");
myXOPArray[k][ bitRead(myCPArray[k], l)];
Serial.print (myXOPArray[k][l]);
Serial.print ("\n");
//Serial.print ("\n");
the output is this
Display the readback address 52
Output X0 = 0
Display the readback address 60
Output X1 = 0
Display the readback address 116
Output X2 = 4
Display the readback address 124
Output X3 = 8
Display the readback address 53
Output X4 = 0
Display the readback address 61
Output X5 = 0
Display the readback address 117
Output X6 = 0
Display the readback address 125
Output X7 = 0
Output X0 Position 0 Data in Array 0
Output X0 Position 1 Data in Array 0
Output X0 Position 2 Data in Array 0
Output X0 Position 3 Data in Array 0
Output X0 Position 4 Data in Array 0
Output X0 Position 5 Data in Array 0
Output X0 Position 6 Data in Array 0
Output X0 Position 7 Data in Array 0
Output X1 Position 0 Data in Array 0
Output X1 Position 1 Data in Array 0
Output X1 Position 2 Data in Array 0
Output X1 Position 3 Data in Array 0
Output X1 Position 4 Data in Array 0
Output X1 Position 5 Data in Array 0
Output X1 Position 6 Data in Array 0
Output X1 Position 7 Data in Array 0
Output X2 Position 0 Data in Array 0
Output X2 Position 1 Data in Array 0
Output X2 Position 2 Data in Array 0
Output X2 Position 3 Data in Array 0
Output X2 Position 4 Data in Array 0
Output X2 Position 5 Data in Array 0
Output X2 Position 6 Data in Array 0
Output X2 Position 7 Data in Array 0
Output X3 Position 0 Data in Array 0
Output X3 Position 1 Data in Array 0
Output X3 Position 2 Data in Array 0
Output X3 Position 3 Data in Array 0
Output X3 Position 4 Data in Array 0
Output X3 Position 5 Data in Array 0
Output X3 Position 6 Data in Array 0
Output X3 Position 7 Data in Array 0
Output X4 Position 0 Data in Array 0
Output X4 Position 1 Data in Array 0
Output X4 Position 2 Data in Array 0
Output X4 Position 3 Data in Array 0
Output X4 Position 4 Data in Array 0
Output X4 Position 5 Data in Array 0
Output X4 Position 6 Data in Array 0
Output X4 Position 7 Data in Array 0
Output X5 Position 0 Data in Array 0
Output X5 Position 1 Data in Array 0
Output X5 Position 2 Data in Array 0
Output X5 Position 3 Data in Array 0
Output X5 Position 4 Data in Array 0
Output X5 Position 5 Data in Array 0
Output X5 Position 6 Data in Array 0
Output X5 Position 7 Data in Array 0
Output X6 Position 0 Data in Array 0
Output X6 Position 1 Data in Array 0
Output X6 Position 2 Data in Array 0
Output X6 Position 3 Data in Array 0
Output X6 Position 4 Data in Array 0
Output X6 Position 5 Data in Array 0
Output X6 Position 6 Data in Array 0
Output X6 Position 7 Data in Array 0
Output X7 Position 0 Data in Array 0
Output X7 Position 1 Data in Array 0
Output X7 Position 2 Data in Array 0
Output X7 Position 3 Data in Array 0
Output X7 Position 4 Data in Array 0
Output X7 Position 5 Data in Array 0
Output X7 Position 6 Data in Array 0
Output X7 Position 7 Data in Array 0
but i would have expected Output X2 Position 2 Data in Array 0
to read Output X2 Position 2 Data in Array 1
and Output X3 Position 3 Data in Array 0
to read Output X3 Position 3 Data in Array 1
what am i doing wrong?
I had a idea!!! i know dangerous right? anyway i changed the bitReader line from
to
myXOPArray[k][l] = bitRead(myCPArray[k],l);
so it now looks like this
Serial.print (k);
Serial.print (" ");
Serial.print (l);
Serial.print (" ");
however it now produces data in the array but its not correct. clearly i am missing something!! output now looks like this
Output X0 = 0
Output X1 = 0
Output X2 = 4
Output X3 = 8
Output X4 = 0
Output X5 = 0
Output X6 = 0
Output X7 = 0
Output X0 Position 2 Data in Array 1
Output X0 Position 4 Data in Array 1
Output X0 Position 5 Data in Array 1
Output X1 Position 2 Data in Array 1
Output X1 Position 3 Data in Array 1
Output X1 Position 4 Data in Array 1
Output X1 Position 5 Data in Array 1
Output X2 Position 4 Data in Array 1
Output X2 Position 5 Data in Array 1
Output X2 Position 6 Data in Array 1
Output X3 Position 2 Data in Array 1
Output X3 Position 4 Data in Array 1
Output X3 Position 5 Data in Array 1
Output X3 Position 6 Data in Array 1
Output X4 Position 0 Data in Array 1
Output X4 Position 2 Data in Array 1
Output X4 Position 4 Data in Array 1
Output X4 Position 5 Data in Array 1
Output X5 Position 0 Data in Array 1
Output X5 Position 2 Data in Array 1
Output X5 Position 3 Data in Array 1
Output X5 Position 4 Data in Array 1
Output X5 Position 5 Data in Array 1
Output X6 Position 0 Data in Array 1
Output X6 Position 2 Data in Array 1
Output X6 Position 4 Data in Array 1
Output X6 Position 5 Data in Array 1
Output X6 Position 6 Data in Array 1
Output X7 Position 0 Data in Array 1
Output X7 Position 2 Data in Array 1
Output X7 Position 3 Data in Array 1
Output X7 Position 4 Data in Array 1
Output X7 Position 5 Data in Array 1
Output X7 Position 6 Data in Array 1
as ever all help gratefully welcomed
thanks
Simon
Finally. A line of code using bitRead() that does something !
I have not looked at the code in detail, but bitRead() works from the least significant bit to the most significant bit, ie right to left. Could that be your problem ?
I don't think so, as that is what i was expecting, in the current test sequences i am only setting x2 to y2 and x3 to y3. I would only expect 0x04 and 0x08 back from x2 and x3 .
so the data i am getting back is useless to me. so clearly i am doing something wrong. i just cant for the life of me figure out what is going on.
Simon
