Hello,
I am trying to convert data sent from a pi-hosted Web-app. If I am correct, the data being sent is string type. I want to convert that data into a float value so I can manipulate it later on. The problem is how to do it.
Here is the code I am using.
String StreamX;
char xFltArr[10];
int SpeedX;
// start serial port at 9600 bps:
StreamX = "";
// if signal from joystick sent, run code
if (Serial.available())
while (Serial.available())
char inByte = Serial.read();
if (inByte == 'x' || inByte == 'y' || inByte == ' ' )
inByte = '0';
StreamX += inByte;
StreamX.toCharArray(xFltArr,10);
SpeedX = float(xFltArr);
Serial.print(SpeedX);
- float() gives me this error: invalid cast from type 'char*' to type 'float'
- Serial.parseFloat() doesn't give an error, however, the pi console seems to crash.
Which leaves atof(). It seems to work fine with this code until I run some math on it, which is where the code goes wrong.
if i type in a number in the serial console on the IDE, the math runs on each digit and then prints it out. For example, if i enter 123 and the code says to multiply SpeedX by 100, it will print 100200300 rather than 12300.
I have been looking up similar problems with atof(), but all i can find is questions about the number of decimals displayed, which is not my problem.
