I'm reading date and time from a cellular breakout and parsing the data into a char array. The date and time from the cell card is in the form of yr/mo/day,hr:min:sec. I send a couple of AT commands and the interaction goes as follows:
AT
OK
AT+CCLK?
+CCLK: "17/03/29,20:46:50-20"
OK
That time is accurate enough for this application and my test sketch has been very stable. However I would like to set my DS3231 RTC on startup and regular intervals using that cellular network time. I've found that I can create these variables to present to the RTC library for setting the RTC:
char yrX = 17;
char moX = 3;
char dayX = 28;
char hrX = 20;
char minX = 31;
char secX = 05;
I've hammered away at google etc for a few days and I'm coming up empty-handed looking for a technique to convert those cellular date and time values stored in an array into variables that the library will accept. I'm open to any suggestions to get it to work, whether it involves reading the cellular time directly into variables, reading into six separate arrays for the various elements of date and time, different RTC libraries, etc.
My test sketch:
#include <SoftwareSerial.h>
#include <Wire.h>
#include "Sodaq_DS3231.h"
SoftwareSerial Cellular(7, 8); // RX, TX
int bufferBinCtr;
//variables for setting the clock
char yrX = 17;
char moX = 3;
char dayX = 28;
char hrX = 20;
char minX = 31;
char secX = 05;
Cellular.begin(9600);
Wire.begin();//Instantiate the RTC
rtc.begin();
bufferBinCtr = 30;//clear cellular buffer
bufferBin(bufferBinCtr);
rtcClockAdjust();//set the clock on startup
delay(9814);//some delay for testing, processes eventually to be scheduled by RTC
ATCCLKPrint();//prints AT and AT+CCLK? to the cell
ATCCLKRead();//read clock output from cell
rtcClockRead();//read RTC
void ATCCLKRead() {
bufferBinCtr = 28;//wastes AT/AT+CCLK preamble
char cbcArray[17];//date/time from cell is in the form of year/mo/dy,hr:mn:sc
int count = 0;
Serial.print("Network time is ");
for(int z8z = 0; z8z < 18; z8z++)
if(Cellular.available() > 0) //test for bytes in buffer
char C = Cellular.read();
//a hyphen comes immediately after :sec
if(C == '-')
int i = 0;
while (i != count)
Serial.print(cbcArray[i++]);
else cbcArray[count++] = C;
Serial.println("");
bufferBinCtr = 12;//burns extraneous bytes at end of buffer
void ATCCLKPrint() {
bufferBinCtr = 30;
Cellular.println("AT");//send "AT", cell responds with "OK"
delay(100);
Cellular.println("AT+CCLK?");//request time from cell
delay(100);
void bufferBin(int xx){
for(int z8z = 0; z8z < xx; z8z++) {
char z8 = Cellular.read();
void rtcClockRead(){
Serial.print("RTC clk time is ");
DateTime now = rtc.now();
Serial.print(now.year(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.date(), DEC);
Serial.print(' ');
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
void rtcClockAdjust()
DateTime dt(yrX, moX, dayX, hrX, minX, secX, 5);
rtc.setDateTime(dt); //Adjust date-time as defined 'dt' above
Thanks in advance for your time.
