Convert char string into char array
Hello I am interfacing the arduino with PC.
But when I am receiving data from PC to arduino, I saves the multiple characters in same variable.
If 'A1' is sent from the PC, the whole thing gets saved in defined variable only (using this "var = Serial.read()")
I want to save both terms in two different variables or an array (I want it to be like this, var[0] = 'A' and var[1] = '1')
M sorry if this question sounds nweb, I googled this thing but could'nt get anything helpful.
Hello,
bparth:
This is not possible because Serial.read() only read one character.
A "char string" is already a char array. Post your code.
Hey brother check this out
Looks like there is a method that will do this that is part of the standard string functionality.
maybe something like this
String myString = "";
while(Serial.available()){
   myString += (char)Serial.read();
char myCharArray[myString.length()];
myString.toCharArray(myCharArray,myString.length());
That might work, but it's a rather excessive approach. As guix pointed out, Serial.read() returns one character at a time already. It's not technically a "char", it's a signed 16-bit integer because it returns -1 if there's no data. You could do something like this:
char mystring[STRLEN_MAX];
uint8_t i = 0;
while (Serial.available() && (i < STRLEN_MAX)) {
  mystring[i] = Serial.read();
  i++;
Alternatively, you can skip the available check:
int rcvd;
uint8_t i;
for (i = 0; i < STRLEN_MAX; i++) {
  rcvd = Serial.read();
  if (rcvd < 0) break;  // Bail out if there's no data
  mystring[i] = (char)rcvd;
