i'm trying to convert a char* which contains 50770 value to integer.
If i use atoi() then i get -14766
if i use cast conversion uint16_t() then i get 1617
if i use cast int() conversion then i get 1904
i want 50770 as int.
Can anyone help me?
I'm assuming you have a character string with those digits?
If you have this:
char *number_string = "50770";
you need to do this to get it as an int:
unsigned int value = atoi (number_string); // notice UNSIGNED int
// now "value" is the integer 50770
The reason you were getting -14766 is that you tried to atoi the string into an int (which is SIGNED). An Arduino int is 16 bits, so the value "50770" stored as a 16 bit signed integer is 50770 - 65536 = -14766. Using an unsigned int allows you to get any number from 0 to 65535. For larger numbers, use a long int (or unsigned long int).
Just FYI, if you instead had a floating point number, you would use atof(), like this:
char *number_string = "123.4567";
float value = atof (number_string);
For that matter, you could use atof() on your integer string, but you would get back the floating point value "50770.000" rather than the integer "50770".
