"Convert" cheap SSD1306 4Wire SPI to II2 ?
I have one of those cheap, 0.96" displays based on the ssd1306 controller. Mine has the pin headers for 4 Wire SPI + reset which takes up 5 pins. Seeing a lot of different versions an ebay with different interfaces, i was wondering, if it could be converterted to i2c interface.
How brave are you. It looks like it can technically be done but without schematic to know of knock on effects by converting from SPI to I2C, not a job for the faint of heart. It will probably also make the display update slower.
Read through this page.
It's 7 pages, so a bit lengthy.
0miker0 has some interesting comments and has build his own PCB to this display.
He has posted schematics too.
I'm not sure he used I2C and / or SPI.
Maybe that can help, but as Riva said, who knows what is on your PCB ?
Riva:
thanks for your anser! Looking at the table you posted -
The pins on may display are labeled D0,D1, CS, D/C. It 'seems that i must at least figure out, where SDAout and SA0 come from. D0,D1 should already be connected to the right "thing", right ?
@MAS3
thx for the pointer -i'm jsu about skimming through...
cider101:
You really need a circuit description to know what effect grounding D3-D7, E, R/W & CS will have. If you use 3-Wire SPI by grounding D/C it will only need one more arduino pin (3 + reset) than I2C (2+ reset).
