convert code 18b20 to dht11
I have the following code for 18B20 sensor for convert from analog temp. to analog voltage output but I have DHT11 can any one help me who to get or convert this code to use with DHT11.
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 2
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
int MIN_TEMP = 0;
int MAX_TEMP = 50;
pinMode(9,OUTPUT);
sensors.begin();
float temperature = getTemperature();
int voltage = temperatureToPWM(temperature);
analogWrite(9,voltage);
float getTemperature()
float temperature =0;
sensors.requestTemperatures(); // Send the command to get temperatures
temperature = sensors.getTempCByIndex(0);
Serial.println(temperature);
return temperature;
int temperatureToPWM(float temperature)
float temp=0;
float voltage = 0;
temp = temperature10;
voltage = map(temp,MIN_TEMP
10,MAX_TEMP*10,0,250);
return voltage;
The two sensors are not at all alike so trying to convert the code is not the route that I would take. Get a DHT11 library and use the example code from that library to develop a sketch for the DHT11.
No need for a completely new sketch.
All you really have to do is replace is the getTemperature() function where the sensor is read; and of course load the appropriate libraries.
