Convert .cpp file into c file
Dear all
I have .cpp file associated with D3231. I have attached.cpp file for reference,
How can I convert below function in C
Is is enough for conversion here
//cpp file
bool DS3231::begin(void)
    Wire.begin();
    setBattery(true, false);
    t.year = 2000;
    t.month = 1;
    t.day = 1;
    t.hour = 0;
    t.minute = 0;
    t.second = 0;
    t.dayOfWeek = 6;
    t.unixtime = 946681200;
    return true;
// c file
 bool DS3231_begin()
 	Wire.begin();
    t.year = 2000;
    t.month = 1;
    t.day = 1;
    t.hour = 0;
    t.minute = 0;
    t.second = 0;
    t.dayOfWeek = 6;
    return true;
My first question is "Why?"
Arduino uses C++. Accessing C methods from C++ requires special flags/code to fix up the method calls.
You use the DS3231 and the Wire class, so if you want to go the pure C, you'll need to rewrite the libraries to pure C too..
+1 with @drmpf, clarify why you would want to do this.
