Convert Easing Functions: Actionscript -> Wiring
Hi! - I’m trying to convert some cubic easing functions from Actionscript to Wiring for use in some motor controller code I am writing. The AS code I am using is based on examples/tutorials by Robert Penner (good stuff: Robert Penner's Easing Functions). The function I am testing is ‘easeInOutCubic’.
When I run it in Wiring I expected to get stepped values from the start value to the change value. Instead what I am getting is: a run of 60, then 1305 in the Serial output window. I understand that Serial.print() truncates floats but I expected to see a range from 60 (start) to 2490 (change amount).
I’m guessing I have some problem with data typing - but that’s a guess. Where I am going with this is to use the easing functions to PWM my motor so it doesn’t lurch to full speed but gradually eases in/out.
Anyway - hope this is clear ::slight_smile: - Any nudges in the right direction much appreciated!
–Roy
-------------ActionScript
function easeInOutCubic(t, b, c, d) {
      if ((t /= d/2)<1) {
            return c/2*Math.pow(t, 3)+b;
      return c/2*(Math.pow(t-2, 3)+2)+b;
-----------Wiring
int time;
int start;
int end;
int change;
int duration;
float speed;
boolean active;
void setup(){
  start = 60;
  end =2550;
  change = end - start;
  time = 0;
  duration = 50 ;
  active = true;
void loop(){
  if (active == true){
    speed = easeInCubic(time++, start, change, duration);
    Serial.println(speed, DEC);
    if (time ==duration){
      active = false;
float easeInOutCubic(int t, int b, int c, int d) {
  if ((t /= d/2)<1) {
    return c/2* pow(t, 3)+b;
  return c/2*(pow(t-2, 3)+2)+b;
float easeInCubic(int t, int b, int c, int d) {
  return c * pow (t/d, 3) + b;
float easeOutCubic(int t, int b, int c, int d) {
  return c * (pow (t/d-1, 3) + 1) + b;
In Wiring/Arduino (i.e. C), when you divide two integers, you get an integer result. In easeInCubic, t and d are both integers with t < d, so you get 0. You need to cast one of them to a float first, something like ((float) t) / d
AH! That helps a lot - I am now seeing a more stepped output - which is what I was expecting. Now I can move on to working on the actual routine.
I don't have much experience with strict data typing or converting between types (casting) so when I run into it it's usually like running face first into a wall.
thanks! :)
--Roy
No problem. This is discussed in the reference for arithmetic: http://www.arduino.cc/en/Reference/Arithmetic but I know that it’s not something you would usually think of as being a problem. This is one of those things that comes along with our underlying language (C/C++) otherwise it’d probably be worth changing the behavior.
