convert Ethernet shield code to wifi ESP8266 board
hi
I’v installed application RCduino from app store to controlling rc car over Eathernet
so I decided to replace arduino Eathernet with Nodemcu wifi
I need help to convert this code to use it with nodemcu
// This is the Arduino source code.
// You need the Arduino connected to an Ethernet Shield.
// The data format is: abcdWWWXXXYYYZZZ
// Where: a, b, c, d are the state of switchs
// WWW, XXX, YYY, ZZZ are the angle (0 to 180)
// to control the servos attached to arduino ports.
// You can select and copy this code.
#include <SPI.h>
#include <Ethernet.h>
#include <Servo.h>
#include <stdlib.h>
#define ch1 2 // Channel 1 - Switch
#define ch2 3 // Channel 2 - Switch
#define ch3 4 // Channel 3 - Switch
#define ch4 5 // Channel 4 - Switch
#define ch5 6 // Channel 5 - Servo (throttle)
#define ch6 7 // Channel 6 - Servo (rudder)
#define ch7 8 // Channel 7 - Servo (aileron)
#define ch8 9 // Channel 8 - Servo (elevator)
byte mac = {0x00, 0xAA, 0xBB, 0xCC, 0xDA, 0x02}; // <<< Your Ethernet Shield mac address
IPAddress ip(192,168,1,101); // <<< Enter your Ethernet Shield IP address here!
EthernetServer server(80);
char c;
char command[16];
boolean incoming = 0;
Servo throttle;
Servo rudder;
Servo aileron;
Servo elevator;
// Setup:
void setup(){
// Switchs:
pinMode(ch1, OUTPUT);
pinMode(ch2, OUTPUT);
pinMode(ch3, OUTPUT);
pinMode(ch4, OUTPUT);
// Servos:
throttle.attach (ch5);
rudder.attach (ch6);
aileron.attach (ch7);
elevator.attach (ch8);
// Initial position:
throttle.write (90);
rudder.write (90);
aileron.write (90);
elevator.write (90);
// Start connection
Ethernet.begin(mac, ip);
server.begin();
// Serial.begin(9600); // For debug
// Main loop:
void loop(){
// Wait for the connection:
if (client) {
while (client.connected()) {
if (client.available()) {
c = client.read();
if (c == ‘$’) incoming = 1;
if (incoming == 1){
// Get the commands:
for (int x=0 ; x<16 ; x++){
c = client.read();
command = c;
//Serial.print(c);// For debug
// The first 4 chars are to control the switchs
if (command [0] == ‘0’) digitalWrite(ch1, LOW);
if (command [0] == ‘1’) digitalWrite(ch1, HIGH);
if (command [1] == ‘0’) digitalWrite(ch2, LOW);
if (command [1] == ‘1’) digitalWrite(ch2, HIGH);
if (command [2] == ‘0’) digitalWrite(ch3, LOW);
if (command [2] == ‘1’) digitalWrite(ch3, HIGH);
if (command [3] == ‘0’) digitalWrite(ch4, LOW);
if (command [3] == ‘1’) digitalWrite(ch4, HIGH);
// Servos:
char s1[4] = {command[4], command[5], command[6], ‘\0’};
char s2[4] = {command[7], command[8], command[9], ‘\0’};
char s3[4] = {command[10], command[11], command[12], ‘\0’};
char s4[4] = {command[13], command[14], command[15], ‘\0’};
// Convert char to int:
int s1i = atol (s1);
int s2i = atol (s2);
int s3i = atoi (s3);
int s4i = atoi (s4);
// Set servo position:
throttle.write (s1i);
rudder.write (s2i);
aileron.write (s3i);
elevator.write (s4i);
incoming = 0;
delay(1);
client.stop();
What help? There are several libraries for working with the ESP8266. Some make it simple. Others do not. Which library are you using?
