Hello All,
Very new to trying coding in the Arduino IDE.
-rtlduino-
Have an existing .c file - example_wlan_repeater , from the amebad_sdk that 'almost' does what I would like it to do albiet i would like to add a function of,when the repeater makes a connection to the AP ( drone AP), the led would blink slowly,dimmly, to verify the repeater actually has a connection to the drone. This .c file does not have the 'LED lights on connection' function.
'example_wlan_repeater .c '
#include <platform_opts.h>
#include "FreeRTOS.h"
#include "task.h"
#include <platform/platform_stdlib.h>
#include "wifi_constants.h"
#include "wifi_structures.h"
#include "lwip_netconf.h"
#include "wifi_conf.h"
#if CONFIG_EXAMPLE_WLAN_FAST_CONNECT
typedef int (*init_done_ptr)(void);
extern init_done_ptr p_wlan_init_done_callback;
extern int wlan_init_done_callback();
#endif
#if CONFIG_BRIDGE
extern void bridgeif_set_mac_init(char *bmac);
extern void bridgeif_add_port_ap_netif(void);
extern void bridgeif_add_port_sta_netif(void);
#endif
#if CONFIG_EXAMPLE_WLAN_REPEATER
#if CONFIG_LWIP_LAYER
extern struct netif xnetif[NET_IF_NUM];
#endif
* @brief Wi-Fi example for mode switch case: Mode switching between concurrent mode and STA and add to bridge.
* @note Process Flow:
* - Disable Wi-Fi
* - Enable Wi-Fi with concurrent (STA + AP) mode
* - Start AP
* - Check AP running
* - Connect to AP using STA mode
static void example_wlan_repeater_thread(void *param)
/* To avoid gcc warnings */
( void ) param;
// Wait for other task stable.
vTaskDelay(4000);
* 1. Enable Wi-Fi with concurrent (STA + AP) mode
printf("\n\r[WLAN_REPEATER_EXAMPLE] Enable Wi-Fi with concurrent (STA + AP) mode\n");
* 1-1. Disable Wi-Fi
printf("\n\r[WLAN_REPEATER_EXAMPLE] Disable Wi-Fi\n");
wifi_off();
vTaskDelay(20);
* 1-2. Enable Wi-Fi with STA + AP mode
printf("\n\r[WLAN_REPEATER_EXAMPLE] Enable Wi-Fi with STA + AP mode\n");
if(wifi_on(RTW_MODE_STA_AP) < 0){
printf("\n\r[WLAN_REPEATER_EXAMPLE] ERROR: wifi_on failed\n");
return;
uint8_t *mac = LwIP_GetMAC(&xnetif[0]);
bridgeif_set_mac_init(mac);
bridgeif_add_port_sta_netif();
bridgeif_add_port_ap_netif();
* 1-3. Start AP
printf("\n\r[WLAN_REPEATER_EXAMPLE] Start AP\n");
char *ssid = "ZLL_drone_base";
char *password = NULL; // NULL for RTW_SECURITY_OPEN
int channel = 6;
if(wifi_start_ap(ssid, (password)?RTW_SECURITY_WPA2_AES_PSK:RTW_SECURITY_OPEN, password, strlen(ssid), (password)?strlen(password):0, channel) < 0) {
printf("\n\r[WLAN_REPEATER_EXAMPLE] ERROR: wifi_start_ap failed\n");
return;
* 1-4. Check AP running
printf("\n\r[WLAN_REPEATER_EXAMPLE] Check AP running\n");
int timeout = 20;
while(1) {
char essid[33];
if(wext_get_ssid(WLAN1_NAME, (unsigned char *) essid) > 0) {
if(strcmp((const char *) essid, (const char *)ssid) == 0) {
printf("\n\r[WLAN_REPEATER_EXAMPLE] %s started\n", ssid);
if(timeout == 0) {
printf("\n\r[WLAN_REPEATER_EXAMPLE] ERROR: Start AP timeout\n");
return;
vTaskDelay(1 * configTICK_RATE_HZ);
timeout --;
* 1-5. Connect to AP using STA mode and start DHCP client
printf("\n\r[WLAN_REPEATER_EXAMPLE] Connect to AP\n");
if(p_wlan_init_done_callback)
p_wlan_init_done_callback();
vTaskDelete(NULL);
void example_wlan_repeater(char* id){
if(xTaskCreate(example_wlan_repeater_thread, ((const char*)"example_wlan_repeater_thread"), 1024, NULL, tskIDLE_PRIORITY + 1, NULL) != pdPASS)
printf("\n\r%s xTaskCreate failed\n", __FUNCTION__);
#endif /* CONFIG_EXAMPLE_WLAN_REPEATER */
Can anyone help on this , in regards to adding the needed code and if it is possible to have a 'converter from the C file to sketch?
Thank You
