Convert flash string to char*
How to pass flash string to function that accepts char* ?
auto myString = F("helloooooow worlddddd");
function myFunction(char *text){
Note: I cannot use String class because the class doesn't implemented well in ATTiny.
Either provide an overloaded function that accepts type (const __FlashStringHelper *), or use ‘strncpy_P()’ to copy the flash string into RAM.
not working :’(
		typedef char *tinyString;
		void Command::response(const tinyString &text) {
			if (responseCallback != nullptr) responseCallback(text);
		void Command::response(const __FlashStringHelper *text) {
			char buffer[20];
			strcpy_P(buffer, text); // <== compile error
			response(text);
YunuZ:
not working :cry:
That's a totally useless problem statement.
Post complete code.
Post complete error message.
			char buffer[20];
			response(text);
gfvalvo:
Post complete code.
Which part of that didn't you understand?
C:\Users\Pesona Fashion\Documents\Arduino\libraries\Marco.Communications.Command\Marco.Communications.Command.cpp: In member function 'void Marco::Communications::Command::response(const __FlashStringHelper*)':
C:\Users\Pesona Fashion\Documents\Arduino\libraries\Marco.Communications.Command\Marco.Communications.Command.cpp:566:25: error: cannot convert 'const __FlashStringHelper*' to 'const char*' for argument '2' to 'char* strcpy_P(char*, const char*)'
This is how I’ve done it:
void response(const __FlashStringHelper *text) {
  const byte textLength = FSHlength(text);
  char buffer[textLength + 1];
  memcpy_P(buffer, text, textLength + 1);  //+1 for the null terminator
  response(buffer);
unsigned int FSHlength(const __FlashStringHelper * FSHinput) {
  PGM_P FSHinputPointer = reinterpret_cast<PGM_P>(FSHinput);
  unsigned int stringLength = 0;
  while (pgm_read_byte(FSHinputPointer++)) {
    stringLength++;
  return stringLength;
Maybe there is a better way.
YunuZ:
What is that all about?
works. thank you.
^^ just a syntax sugar
the tinyString is more human readable than char*
You’re welcome. I’m glad if I was able to be of assistance.
Heres another way
const char myString[] PROGMEM = "this is my String";  //string saved in flash
char   a;
a=pgm_read_byte(myString);
Serial.print(a); //prints out a byte in a string
