Convert Hex-String like "00008BFC" to double/integer
In my project, my Arduino Micro receives signals from a rotation mount where the position is described by a hex-8 digit string like “00008BFC” which corresponds to 35836 in decimal basis. Only the last 4 digits are used. However, for negative values I get something like “FFFFB9F8”. After literally hours of reading and testing, I couldn’t find a solution to convert this into an integer or other variable type. I hope you can help me. I tried different functions like sscanf but didn’t succeed. My current approach is very basic but still produces errors.
int hex2int(char ch)
    if (ch >= '0' && ch <= '9')
        return ch - '0';
    if (ch >= 'A' && ch <= 'F')
        return ch - 'A' + 10;
    if (ch >= 'a' && ch <= 'f')
        return ch - 'a' + 10;
    return -1;
double convert(char* position){
  Serial.print("Convert: ");
  Serial.println(position);
  Serial.print("pos[3]*16^4=65536*");
  Serial.print(hex2int(position[3]));
  Serial.print("=");
  double val1=hex2int(position[3])*65536;
  Serial.println(val1);
  Serial.print("pos[4]*16^3=4096*");
  Serial.print(hex2int(position[4]));
  Serial.print("=");
  double val2=hex2int(position[4])*4096;
  Serial.println(val2);
  Serial.print("pos[5]*16^2=256*");
  Serial.print(hex2int(position[5]));
  Serial.print("=");
  double val3=hex2int(position[5])*256;
  Serial.println(val3);
   Serial.print("pos[6]*16^1=16*");
  Serial.print(hex2int(position[6]));
  Serial.print("=");
  double val4=hex2int(position[6])*16;
  Serial.println(val4);
  Serial.print("pos[7]*16^0=1*");
  Serial.print(hex2int(position[7]));
  Serial.print("=");
  double val5=hex2int(position[7]);
  Serial.println(val5);
  double val = val1+val2+val3+val4+val5;
  Serial.print("Total: ");
  Serial.println(val);
  return val;
 convert("00008BFC");
 delay(5000);
I get the output:
Convert: 00008BFC
pos[3]*16^4=65536*0=0.00
pos[4]*16^3=4096*8=-32768.00
pos[5]*16^2=256*11=2816.00
pos[6]*16^1=16*15=240.00
pos[7]*16^0=1*12=12.00
Total: -29700.00
Can you tell me why I get -32768.00 instead of 524288. I can understand that I run into errors multiplying by something like 16^6, but in this case?!
Do you have a simple solution for me how to convert these strings? There are also negative values like “FFFFB9F8” that I don’t know how to deal with yet. I also need the other direction creating those strings. I would really appreciate your help.
Edit: Typo in the code changed.
Misuse of the XOR operator ^
Joking.
val1=hex2int(position[3])*65536 Sixteen bit ints, don’t forget
get following result
35836
using
void setup (void)
    unsigned int val;
    const char*  s = "008bFC";
    sscanf (s, "%x", &val);
    Serial.begin (9600);
    Serial.println (val);
void loop (void)
I use the standard function strtoul().
  unsigned long x = strtoul("00008BFC", NULL, 16);
  Serial.println(x); //prints 35836
TheMemberFormerlyKnownAsAWOL:
Thanks! I somehow thought I am working on 32 bits :slight_smile:
I tried to simplify the function and found another weird thing
  for(int i=3;i<5;i++){
    Serial.println(pow(16,7-i));
returns:
65535.95
4096.00
While the same function with i<4 returns 65536.00. I can also use doubles for all variables with the same result
  double exponent=7;
  double base=16;
  for(double i=3;i<5;i++){
    Serial.println(pow(base,exponent-i));
What’s going on here?
pow() uses floating point math with logarithm and exponential functions. It is best avoided when calculating integer powers.
