convert hours:min:sec to TM1637 4 digits
hello!
i am trying to make a simple timer to countdown from 20 min to 0sec. So far, eveything works and i can see that it works as it should using the serial monitor.
My problem is how do i convert the time stamp hours:min:sec to just min and sec so it will "fit" in the TM1637?
#include "Countimer.h"
#include <TM1637Display.h>
#define CLK 2
#define DIO 3
TM1637Display display(CLK, DIO);
Countimer tDown;
boolean timePause = 1;
boolean timePlay = 0;
//button setup
int startButton = 7;//pin bouton
int resetButton = 8;//
int greenLed = 13;//
//debounce
long lastDebounceTime = 0;
long debounceDelay = 30;
    display.setBrightness(5);
    //display.setSegments(data);
    delay(50);
 pinMode(greenLed, OUTPUT);
  pinMode(startButton, INPUT_PULLUP);
  pinMode(resetButton, INPUT_PULLUP);
    // Count-down timer with 21s
	tDown.setCounter(0, 00, 10, tDown.COUNT_DOWN, tDownComplete);
    // Call print_time2() method every 1s.
	tDown.setInterval(print_time2, 1000);
	tDown.run();
if ( (millis() - lastDebounceTime) > debounceDelay) {
  if ((digitalRead(startButton) == 0) && timePlay == 0) {
        digitalWrite(greenLed, HIGH);
        timePlay = 1;
        tDown.start();
        lastDebounceTime = millis();
        delay(100);
  if ((digitalRead(startButton) == 0) && timePlay == 1) {
        digitalWrite(greenLed, LOW);
        timePlay = 0;
        tDown.pause();
        delay(100);
 if ((digitalRead(resetButton) == 0)) {
  delay(50);
        timePlay = 0;
        tDown.restart();
        tDown.pause();
        delay(100);
    print_time2();
void print_time2()
	//Serial.print("tDown: ");
	Serial.println(tDown.getCurrentTime());
 // This displays the seconds in the last two places
    display.showNumberDecEx(seconds, 0, true, 2, 2);
    // Display the minutes in the first two places, with colon
    display.showNumberDecEx(minutes, 0x80>>3, true, 2, 0);
    //delay(1000);
void tDownComplete()
