How do I convert a long to a string? Example code below:
test ID
unsigned long testID = 1716526225;
sprintf(buf, "GET /testID=%d HTTP/1.0", testID);
Output is: GET /testID=0 HTTP/1.0
Any ideas?
test ID
Any ideas?
How do I convert an unsigned long to a string?
sprintf(buf, "GET /testID=[glow]%lu[/glow] HTTP/1.0", testID);
hmmm... that doesn't seem to work. I get the following results:
GET /testID=7313 HTTP/1.0
Should be:
GET /testID= 1716526225 HTTP/1.0
Works fine for me...
void setup( void )
Serial.begin( 57600 );
void loop( void )
char buf[50];
sprintf(buf, "GET /testID=%lu HTTP/1.0", testID);
Serial.println( buf );
delay( 1000 );
GET /testID=1716526225 HTTP/1.0
Instead of calling sprintf you could also use ltoa which consumes less resources and use the Streaming library if a single line or string concatenation is desired.
Code snippet:
char buf[50];
ltoa(testID, buf, 10); // 10 is the base value not the size - look up ltoa for avr
Serial << "GET /testID=" << testID << " HTTP/1.0" << endl; // Streaming.h
delay( 1000 );
or
char buf[50];
Serial.print("GET /testID=");
Serial.print(testID);
Serial.println(" HTTP/1.0");
delay( 1000 );
Cheers,
Eric
