I'd like to make something similar like this, with a 8x8 LED matrix Single color, but on a bigger scale.
It's basically a low resolution fire animation.
The guy who made this works with a RGB led grid and drives it with a rainbowduino. He also provides the code.
I would like to make a similar animation, but with single color led matrix, and would like to know if its possible to convert the code to work with a MAX7219 driver.
KurtVdN:
It will be difficult. The MAX7219 doesn't play nice with RGB matrices (this is the main reason why they invented the rainbowduino!)
These days you'd just chop up a WS2812 LED strip and use that instead. It's very cheap and easy to build using strips.
Thanks for your answer.
No, the thing is that I would not use a RGB matrix. I want the 'fire' effect but would only use a single color matrix.
Is the code convertable to use it with a MAX7219, but without the RGB functionality?
KurtVdN:
Not really - the MAX7219 can't set the brightness of individual LEDs. They're either on or off.
