Convert seconds to hours
Hello,
I want to convert seconds to hours but I can’t find how.
The problem is thath I am measuring how many hours (each day the sun shines).
But as you know the sun shines in unpredictable patterns.
So setting 3600 seconds to 1 hour won’t work because if the sun only shines for 1500 seconds it won’t count as an hour.
Ive been looking for a solution and tried many different things but I can’t seem to find it.
Do you recall how to do division?
Paul
I don't understand your question. Do you mean that you want hour as a floating point value, e.g. 1500 seconds = 1500/3600 = 0.417 hour ?
how about using a float, 1800 seconds = 0.5 hours, ...
so to get the hours without loosing too much value:
float hours = value / 3600.0f
gives .5 hours for 1800 seconds, 2.0 hours for 7200 seconds
just keep in mind, in statistics raw data is awesome :smiley:
guix:
Do you want to see your time in this format?
GolamMostafa:
a bit overkill but useful depending on what you are planning to do in the future might be the time library
So setting 3600 seconds to 1 hour won't work because if the sun only shines for 1500 seconds it won't count as an hour.
You are correct, less than an hour does not count asan hour. I see no problem here!
rico459:
1500 seconds isn't an hour. So why should it count as an hour? Does 1 second count as an hour?
What are you actually trying to achieve?
Steve
rico459:
The problem is that I am measuring how many hours (each day the sun shines).
I is not quite as unpredictable as you seem to imply. In fact, in pre-historic times, large stone calendars were built which depended on the predictability of the sun's movement (at least, relative to the earth)
int totalSeconds = 4766;
int hr = totalSeconds div 3600;
int min = (totalSeconds - 3600hr) div 60;
int sec = totalSeconds - 3600
hr - 60*min;
jrdoner:
hr - 60*min;
got it thank you!
