Convert string to int
Hello,
I wish to convert string to int but i have lot of problems
Here you have my code :
#include <stdlib.h>
char recu[20];
String reponse;
int i=0;
   i=0;
   while ( Serial.available()>0 )      {
       recu[i] = Serial.read();
       //Serial.println(recu[i]);
       if (recu[i]=='-')
         //On arrete le transfert et on met à zero la reception
          Serial.println("Fin de reception");
          Serial.println("Avant Suppression= "+ reponse);
          //On vide l'ancienne valeur
          reponse="";
       else if (recu[i]=='+')
          Serial.println("Debut de reception");
       else if (recu[i]=='*')
          Serial.println("Relance du transfert");
       }else
         reponse += recu[i];
         i++;
   if (i>0)
      Serial.println(reponse);
//How can i do here to convert reponse to int value
i want to transform response = "123658" to i=123658
How can i do ?
I use arduino uno
thanks
I am deleting your other post if it is a duplicate of this one ...
I can imagine that you do, because you don't have a string. You have a String, which is a completely different thing altogether.
The String class has a toInt() method that you could have found by looking at the documentation.
Some servo test code that has "int value = inString.toInt(); ".
// Serial Servo Tester 10/28/11
// Use the Serial Monitor to write a value from 0 to 180
// Set Serial Monitor line ending to Newline
// for writeMicroseconds, use values from  544 to 2400
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
String inString;
  myservo.attach(9);  //the pin for the servo control
  Serial.println("Enter angle between 0 and 180 (values > 544 written as Microseconds)");
  while (Serial.available()> 0) {
    int inChar = Serial.read();
    if (isDigit(inChar))
      // if the incoming character is a digit, add it to the string
      inString += (char)inChar;
      // here on the first character that is not a digit
      if(value >= 544)
        Serial.print("writing Microseconds: ");
        Serial.println(value);
        myservo.writeMicroseconds(value);
        Serial.print("writing Angle: ");
        myservo.write(value);
      // clear the string for new input:
      inString = "";
