I need to know how to convert char to its decimal equivalent for example I have J in a char array I need to convert it to 74 which is the decimal equalant for J in ASCII.
Tried atoi,atol didn't help
also tried creating an array from 0- 100 like this char ascii[ ]={'','','','','',''} but It doesn't work after ♪ character
Any help is appreciated
Thanks
Serial.print ('J', HEX);
You will need to apply appropriate indices.
Thank you for the reply but how can I put char array element into something like this and get the output to an integer?
You could cast the char element to a byte or unsigned integer.
all data is binary. you can represent data it in many different ways that are all equivalent
the code below produces
val is 74
val is 'J'
val is 0x4A
0 0x00
1 0x01
2 0x02
3 0x03
4 0x04
5 0x05
6 0x06
7 0x07 a
8 0x08
9 0x09
10 0x0a
11 0x0b
12 0x0c
13 0x0d
14 0x0e
15 0x0f
16 0x10
17 0x11
18 0x12
19 0x13
20 0x14
21 0x15
22 0x16
23 0x17
24 0x18
25 0x19
26 0x1a
27 0x1b e
28 0x1c
29 0x1d
30 0x1e
31 0x1f
32 0x20
33 0x21 !
34 0x22 "
35 0x23 #
36 0x24 $
37 0x25 %
38 0x26 &
39 0x27 '
40 0x28 (
41 0x29 )
42 0x2a *
43 0x2b +
44 0x2c ,
45 0x2d -
46 0x2e .
47 0x2f /
48 0x30 0
49 0x31 1
50 0x32 2
51 0x33 3
52 0x34 4
53 0x35 5
54 0x36 6
55 0x37 7
56 0x38 8
57 0x39 9
58 0x3a :
59 0x3b ;
60 0x3c <
61 0x3d =
62 0x3e >
63 0x3f ?
64 0x40 @
65 0x41 A
66 0x42 B
67 0x43 C
68 0x44 D
69 0x45 E
70 0x46 F
71 0x47 G
72 0x48 H
73 0x49 I
74 0x4a J
75 0x4b K
76 0x4c L
77 0x4d M
78 0x4e N
79 0x4f O
80 0x50 P
81 0x51 Q
82 0x52 R
83 0x53 S
84 0x54 T
85 0x55 U
86 0x56 V
87 0x57 W
88 0x58 X
89 0x59 Y
90 0x5a Z
91 0x5b [
92 0x5c \
93 0x5d ]
94 0x5e ^
95 0x5f _
96 0x60 `
97 0x61 a
98 0x62 b
99 0x63 c
100 0x64 d
101 0x65 e
102 0x66 f
103 0x67 g
104 0x68 h
105 0x69 i
106 0x6a j
107 0x6b k
108 0x6c l
109 0x6d m
110 0x6e n
111 0x6f o
112 0x70 p
113 0x71 q
114 0x72 r
115 0x73 s
116 0x74 t
117 0x75 u
118 0x76 v
119 0x77 w
120 0x78 x
121 0x79 y
122 0x7a z
123 0x7b {
124 0x7c |
125 0x7d }
126 0x7e ~
127 0x7f
byte val = 74;
char s [80];
void
scan ()
for (int n = 0; n < 128; n++) {
sprintf (s, " %4d 0x%02x %c", n, n, n);
Serial.println (s);
void setup ()
Serial.begin (9600);
if (74 == val)
Serial.println (" val is 74");
if ('J' == val)
Serial.println (" val is 'J'");
if (0x4A == val)
Serial.println (" val is 0x4A");
scan ();
void loop () {
Some notes:
7 0x07 'a' ASCII BEL (Bell), a.k.a 'alert'
9 0x09 ' ' ASCII TAB ('\t')
10 0x0a '
' ASCII LF (Linefeed/Newline, '\n')
13 0x0d '
' ASCII CR (Return/Enter, '\r')
27 0x1b 'e' ASCII ESC (Escape)
32 0x20 ' ' (Space)
Thank you very much it helped a lot
Thank you for your help
