I found a sketch that sends bpm from midi clock to a TM1637 Display GitHub,
I'm attempting to send that bpm data to a TFT Display instead,
but I get random symbols on the TFT Display instead of numbers,
can anyone see what I'm doing wrong?
#include <TimerOne.h>
For all features: if you do not define the pin, the feature will be disabled!
FEATURE: TAP BPM INPUT
#define TAP_PIN 2
#define TAP_PIN_POLARITY RISING
#define MINIMUM_TAPS 3
#define EXIT_MARGIN 150 // If no tap after 150% of last tap interval -> measure and set
FEATURE: DIMMER BPM INPUT
// #define DIMMER_INPUT_PIN A0
//#define DIMMER_CHANGE_MARGIN 20 // Big value to make sure this doesn't interfere. Tweak as needed.
FEATURE: DIMMER BPM INCREASE/DECREASE
//#define DIMMER_CHANGE_PIN A1
//#define DEAD_ZONE 50
//#define CHANGE_THRESHOLD 5000
//#define RATE_DIVISOR 30
FEATURE: BLINK TEMPO LED
#define BLINK_OUTPUT_PIN 3
#define BLINK_PIN_POLARITY 0 // 0 = POSITIVE, 255 - NEGATIVE
#define BLINK_TIME 4 // How long to keep LED lit in CLOCK counts (so range is [0,24])
FEATURE: SYNC PULSE OUTPUT
//#define SYNC_OUTPUT_PIN 4 // Can be used to drive sync analog sequencer (Korg Monotribe etc ...)
//#define SYNC_PIN_POLARITY 0 // 0 = POSITIVE, 255 - NEGATIVE
FEATURE: Send MIDI start/stop
#define START_STOP_INPUT_PIN 4
#define START_STOP_PIN_POLARITY 0 // 0 = POSITIVE, 1024 = NEGATIVE
#define MIDI_START 0xFA
#define MIDI_STOP 0xFC
#define DEBOUNCE_INTERVAL 500L // Milliseconds
FEATURE: EEPROM BPM storage
#define EEPROM_ADDRESS 0 // Where to save BPM
#ifdef EEPROM_ADDRESS
#include <EEPROM.h>
#endif
FEATURE: MIDI forwarding
#define MIDI_FORWARD
FEATURE: TFT display BPM output
#define TFT_DISPLAY
#ifdef TFT_DISPLAY
#include <TFT.h>
#define lcd_cs 10
#define dc 9
#define rst 8
// create an instance of the library
TFT TFTscreen = TFT(lcd_cs, dc, rst);
#endif
GENERAL PARAMETERS
#define MIDI_TIMING_CLOCK 0xF8
#define CLOCKS_PER_BEAT 24
#define MINIMUM_BPM 400 // Used for debouncing
#define MAXIMUM_BPM 3000 // Used for debouncing
long intervalMicroSeconds;
int bpm; // BPM in tenths of a BPM!!
boolean initialized = false;
long minimumTapInterval = 60L * 1000 * 1000 * 10 / MAXIMUM_BPM;
long maximumTapInterval = 60L * 1000 * 1000 * 10 / MINIMUM_BPM;
volatile long firstTapTime = 0;
volatile long lastTapTime = 0;
volatile long timesTapped = 0;
volatile int blinkCount = 0;
int lastDimmerValue = 0;
boolean playing = false;
long lastStartStopTime = 0;
//#ifdef TM1637_DISPLAY
//TM1637Display display(TM1637_CLK_PIN, TM1637_DIO_PIN);
uint8_t tft_data[4] = {0x00, 0x00, 0x00, 0x00};
//#endif
#ifdef DIMMER_CHANGE_PIN
long changeValue = 0;
#endif
// Set MIDI baud rate:
//Serial.begin(31250);
TFTscreen.begin();
TFTscreen.background(0, 0, 0);
TFTscreen.setRotation(1);
TFTscreen.setTextSize(2);
TFTscreen.stroke(255, 255, 255);
// Set pin modes
#ifdef BLINK_OUTPUT_PIN
pinMode(BLINK_OUTPUT_PIN, OUTPUT);
#endif
#ifdef SYNC_OUTPUT_PIN
pinMode(SYNC_OUTPUT_PIN, OUTPUT);
#endif
#ifdef DIMMER_INPUT_PIN
pinMode(DIMMER_INPUT_PIN, INPUT);
#endif
#ifdef START_STOP_INPUT_PIN
pinMode(START_STOP_INPUT_PIN, INPUT);
#endif
// Get the saved BPM value from 2 stored bytes: MSB LSB
bpm = EEPROM.read(EEPROM_ADDRESS) << 8;
bpm += EEPROM.read(EEPROM_ADDRESS + 1);
if (bpm < MINIMUM_BPM || bpm > MAXIMUM_BPM) {
bpm = 1200;
#endif
#ifdef TAP_PIN
// Interrupt for catching tap events
attachInterrupt(digitalPinToInterrupt(TAP_PIN), tapInput, TAP_PIN_POLARITY);
#endif
// Attach the interrupt to send the MIDI clock and start the timer
Timer1.initialize(intervalMicroSeconds);
Timer1.setPeriod(calculateIntervalMicroSecs(bpm));
Timer1.attachInterrupt(sendClockPulse);
// Initialize dimmer value
lastDimmerValue = analogRead(DIMMER_INPUT_PIN);
#endif
display.setBrightness(TM1637_BRIGHTNESS);
setDisplayValue(bpm);
#endif
long now = micros();
#ifdef TAP_PIN
Handle tapping of the tap tempo button
if (timesTapped > 0 && timesTapped < MINIMUM_TAPS && (now - lastTapTime) > maximumTapInterval) {
// Single taps, not enough to calculate a BPM -> ignore!
timesTapped = 0;
} else if (timesTapped >= MINIMUM_TAPS) {
long avgTapInterval = (lastTapTime - firstTapTime) / (timesTapped - 1);
if ((now - lastTapTime) > (avgTapInterval * EXIT_MARGIN / 100)) {
bpm = 60L * 1000 * 1000 * 10 / avgTapInterval;
updateBpm(now);
// Update blinkCount to make sure LED blink matches tapped beat
blinkCount = ((now - lastTapTime) * 24 / avgTapInterval) % CLOCKS_PER_BEAT;
timesTapped = 0;
#endif
Handle change of the dimmer input
int curDimValue = analogRead(DIMMER_INPUT_PIN);
if (curDimValue > lastDimmerValue + DIMMER_CHANGE_MARGIN
|| curDimValue < lastDimmerValue - DIMMER_CHANGE_MARGIN) {
// We've got movement!!
bpm = map(curDimValue, 0, 1024, MINIMUM_BPM, MAXIMUM_BPM);
updateBpm(now);
lastDimmerValue = curDimValue;
#endif
int curDimValue = analogRead(DIMMER_CHANGE_PIN);
if (bpm > MINIMUM_BPM && curDimValue < (512 - DEAD_ZONE)) {
int val = (512 - DEAD_ZONE - curDimValue) / RATE_DIVISOR;
changeValue += val * val;
} else if (bpm < MAXIMUM_BPM && curDimValue > (512 + DEAD_ZONE)) {
int val = (curDimValue - 512 - DEAD_ZONE) / RATE_DIVISOR;
changeValue = 0;
if (changeValue > CHANGE_THRESHOLD) {
bpm += curDimValue < 512 ? -1 : 1;
updateBpm(now);
changeValue = 0;
#endif
Check for start/stop button pressed
boolean startStopPressed = (START_STOP_PIN_POLARITY - digitalRead(START_STOP_INPUT_PIN)) == HIGH;
if (startStopPressed && (lastStartStopTime + (DEBOUNCE_INTERVAL * 1000)) < now) {
startOrStop();
lastStartStopTime = now;
#endif
#ifdef MIDI_FORWARD
Forward received serial data
while (Serial.available()) {
int b = Serial.read();
Serial.write(b);
#endif
void tapInput() {
if (now - lastTapTime < minimumTapInterval) {
return; // Debounce
if (timesTapped == 0) {
firstTapTime = now;
timesTapped++;
lastTapTime = now;
void startOrStop() {
if (!playing) {
Serial.write(MIDI_START);
Serial.write(MIDI_STOP);
playing = !playing;
void sendClockPulse() {
// Write the timing clock byte
Serial.write(MIDI_TIMING_CLOCK);
blinkCount = (blinkCount + 1) % CLOCKS_PER_BEAT;
if (blinkCount == 0) {
// Turn led on
analogWrite(BLINK_OUTPUT_PIN, 255 - BLINK_PIN_POLARITY);
#endif
// Set sync pin to HIGH
analogWrite(SYNC_OUTPUT_PIN, 255 - SYNC_PIN_POLARITY);
#endif
if (blinkCount == 1) {
// Set sync pin to LOW
analogWrite(SYNC_OUTPUT_PIN, 0 + SYNC_PIN_POLARITY);
#endif
if (blinkCount == BLINK_TIME) {
// Turn led on
analogWrite(BLINK_OUTPUT_PIN, 0 + BLINK_PIN_POLARITY);
#endif
void updateBpm(long now) {
// Update the timer
long interval = calculateIntervalMicroSecs(bpm);
Timer1.setPeriod(interval);
// Save the BPM in 2 bytes, MSB LSB
EEPROM.write(EEPROM_ADDRESS, bpm / 256);
EEPROM.write(EEPROM_ADDRESS + 1, bpm % 256);
#endif
#ifdef TFT_DISPLAY
#endif
long calculateIntervalMicroSecs(int bpm) {
// Take care about overflows!
return 60L * 1000 * 1000 * 10 / bpm / CLOCKS_PER_BEAT;
#ifdef TFT_DISPLAY
void setDisplayValue(int value) {
// tft_data[0] = value >= 1000 ? display.encodeDigit(value / 1000) : 0x00;
// tft_data[1] = value >= 100 ? display.encodeDigit((value / 100) % 10) : 0x00;
// tft_data[2] = value >= 10 ? display.encodeDigit((value / 10) % 10) : 0x00;
// tft_data[3] = display.encodeDigit(value % 10);
//delete old number
//print new text
TFTscreen.text(bpm, 15, 50);
#endif
