Hi David,
Thank you for your reply. I am trying to find a close match to the BigFont numbers.
Referring to the attached test code, could you advise me how to use the FreeBigFonts?
Kind regards
It seems that the author of the big fonts modified the original UTFT fonts. I have the .c file and so my original question was is it possible to adapt them to a GFX type?
I suggest that you look at the large range of fonts available from U8g2lib
I don't think that any of the FreeFonts that come with Adafruit_GFX match your JPG
And UTFT's BigFont certainly does not match the 7.022.79
But the SPLIT looks pretty horrible. That looks like UTFT BigFont
The UTFT website has a whole range of ugly fonts that you can choose.
It is your project. You make the decisions for which Fonts to use.
There are many designed for small LCD displays. And many designed for your PC monitor. If you specify which font you want to use, we can probably tell you where to find a ready-made version for your GFX or how to create a compatible FreeFont yourself.
If you specify which UTFT font you want, I can create a FreeFont for you.
Which display do you want to use?
The Sainmart one says 240x320 SSD1289. I doubt if it really is SSD1289. But it is definitely 16-bit Parallel
The Adafruit one is 320x480 HX8357D. You can use SPI or Parallel
The Sainsmart has an SPI Touch Controller chip
The Adafruit has bare resistive screen.
Please make a nice cup of tea. Think about what you want.
Oh. Your links need editing you have extraneous right-parenthesis and period in both URLs.
