Using a ph stamp I can print out readings from a string to serial //Serial.println()
But I'm also trying to print the readings to a TFT screen. The library to print to the screen requires the following to print to a TFT, my.GLCD(char* , int, int); The 2 integers are the X and Y co-ordinates on the screen.
In order to convert the string to char* I used
char* buf;
string.toCharArray(buf,len);
When I try to print the buf to the Serial Com or the TFT I get blank characters, (the screen keeps scrolling)
My buffer is called "lolz"
Here's my code
String inputstring = "";
String sensorstring = "";
boolean input_stringcomplete = false;
boolean sensor_stringcomplete = false;
#include <ITDB02_Graph16.h>
#include <ITDB02_Touch.h>
#include <DS1307.h>
//Display Setup
ITDB02 myGLCD(38,39,40,41,ITDB32S);
ITDB02_Touch myTouch(6,5,4,3,2);
extern uint8_t SmallFont[];
extern uint8_t BigFont[];
//a string to hold incoming data from the PC
//a string to hold the data from the Atlas Scientific product
//have we received all the data from the PC
//have we received all the data from the Atlas Scientific
//product
void setup(){
Serial.begin(38400);
Serial3.begin(38400);
inputstring.reserve(5);
sensorstring.reserve(30);
// Initial setup
myGLCD.InitLCD(LANDSCAPE);
myGLCD.clrScr();
myGLCD.setFont(BigFont);
myTouch.InitTouch(LANDSCAPE);
myTouch.setPrecision(PREC_MEDIUM);
//set up the hardware
//set baud rate for the hardware serial port_0 to 38400
//set baud rate for software serial port_3 to 38400
//set aside some bytes for receiving data from the PC
//set aside some bytes for receiving data from Atlas Scientific
//product
void serialEvent() {
char inchar = (char)Serial.read();
inputstring += inchar;
if(inchar == '\r') {input_stringcomplete = true;}
//if the hardware serial port_0 receives
//a char
//get the char we just received
//add it to the inputString
//if the incoming character is a <CR>,
//set the flag
void serialEvent3(){
char inchar = (char)Serial3.read();
sensorstring += inchar;
if(inchar == '\r') {sensor_stringcomplete = true;}
//if the hardware serial port_3 receives
//a char
//set the flag
void loop(){
if (input_stringcomplete){
Serial3.print(inputstring);
inputstring = "";
//here we go...
//if a string from the PC has been received in its entierty
//send that string to the Atlas Scientific product
//clear the string:
//reset the flag used to tell if we have received a completed
//string from the PC
char* lolz;
sensorstring.toCharArray(lolz,10);
myGLCD.setColor(255,0,0);
if (sensor_stringcomplete){
myGLCD.print(lolz,180,180);
Serial.println(lolz);
sensorstring = "";
//if a string from the Atlas Scientific product has been
//received in its entierty
//send that string to to the PC's serial monitor
//clear the string:
//completed string from the Atlas Scientific product
When I use Serial.print(sensorstring); it displays the value in the serial com. But I cant use a string to print to TFT.
Managed to get the value displayed in Serial.print to show on my TFT using the following code
This software was made to demonstrate how to quickly get your Atlas Scientific product running on the Arduino platform.
An Arduino MEGA 2560 board was used to test this code.
This code was written in the Arudino 1.0 IDE
Modify the code to fit your system.
**Type in a command in the serial monitor and the Atlas Scientific product will respond.**
**The data from the Atlas Scientific product will come out on the serial monitor.**
Code efficacy was NOT considered, this is a demo only.
The TX3 line goes to the RX pin of your product.
The RX3 line goes to the TX pin of your product.
Make sure you also connect to power and GND pins to power and a common ground.
Open TOOLS > serial monitor, set the serial monitor to the correct serial port and set the baud rate to 38400.
Remember, select carriage return from the drop down menu next to the baud rate selection; not "both NL & CR".
String inputstring = ""; //a string to hold incoming data from the PC
String sensorstring = ""; //a string to hold the data from the Atlas Scientific product
boolean input_stringcomplete = false; //have we received all the data from the PC
boolean sensor_stringcomplete = false; //have we received all the data from the Atlas Scientific product
void setup(){ //set up the hardware
Serial.begin(38400); //set baud rate for the hardware serial port_0 to 38400
Serial3.begin(38400); //set baud rate for software serial port_3 to 38400
inputstring.reserve(5); //set aside some bytes for receiving data from the PC
sensorstring.reserve(30); //set aside some bytes for receiving data from Atlas Scientific product
myGLCD.clrScr();
void serialEvent() { //if the hardware serial port_0 receives a char
char inchar = (char)Serial.read(); //get the char we just received
inputstring += inchar; //add it to the inputString
if(inchar == '\r') {input_stringcomplete = true;} //if the incoming character is a <CR>, set the flag
void serialEvent3(){ //if the hardware serial port_3 receives a char
char inchar = (char)Serial3.read(); //get the char we just received
sensorstring += inchar; //add it to the inputString
if(inchar == '\r') {sensor_stringcomplete = true;} //if the incoming character is a <CR>, set the flag
void loop(){ //here we go....
if (input_stringcomplete){ //if a string from the PC has been recived in its entierty
Serial3.print(inputstring); //send that string to the Atlas Scientific product
inputstring = ""; //clear the string:
input_stringcomplete = false; //reset the flage used to tell if we have recived a completed string from the PC
if (sensor_stringcomplete){ //if a string from the Atlas Scientific product has been recived in its entierty
Serial.println(sensorstring); //Print to PC's serial monitor
char lolz[30];
sensorstring.toCharArray(lolz,30);
int phread = atoi(lolz);
char phprint[30];
itoa (phread,phprint,30);
myGLCD.setColor(255,0,0); //Print to TFT
myGLCD.print(phprint,180,180);
sensorstring = ""; //clear the string:
sensor_stringcomplete = false; //reset the flage used to tell if we have recived a completed string from the Atlas Scientific product
The problem is that I lose the decimal values using this code so instead of reading a ph of 7.42 It only reads 7 on the TFT.
itoa will stop converting when it encounters a non-numeric character (like a period). May that is it? If the device is returning the ph value as 7.42, you will need to parse the string with a period and itoa convert the value after the decimal point also.
char lolz[30];
int phint = atoi(lolz);
int phfract;
if(lolz[1] == '.') phfract = atoi(&lolz[2]);
else phfract = atoi(&lolz[3]);
char phprint[30];
itoa (phfract,phprint,30);
Its now printing x.x to both serial and TFT, it needs to be x.xx though....
what can we change to get it to do both decimals?
Thanks again!
char lolz[30];
int phfract;
char intprint[30];
char fractprint[30];
itoa (phint,intprint,30);
itoa (phfract,fractprint,30);
Serial.print(intprint);
Serial.print(",");
Serial.println(fractprint);
myGLCD.print(intprint,180,180);
myGLCD.print(".",195,180);
myGLCD.print(fractprint,203,180);
If I add ,DEC to Serial.print I get a error: call of overloaded 'print(char [30], int)' is ambiguous.
Further testing now actually gives me X.XX but the fraction part does not read what its suppose to.
Its reads stuff like:
7,j2
7,a3
7,11
7,1j
etc...
using code
char lolz[30];
int phfract;
char intprint[30];
Serial.print(",");
if(phfract < 10) Serial.print("0");
