Converting a 5-byte big number to a number?
I'm reading data from a device that returns a lot of bytes. 5 bytes are representing a big number that I need. For example, I receive 24C9A75A2E and it means the value is 158002010670.
These bytes are in a byte array positions 5 to 9.
I tried converting this number to a long like this:
long long val = 0;
val += (long)dataRx[9] << 32;
val += (long)dataRx[8] << 24;
val += (long)dataRx[7] << 16;
val += (long)dataRx[6] << 8;
val += (long)dataRx[5];
But that did 't seem to work.
Can anyone help me out?
Well, what did you get?
Post a small sketch that shows what went wrong. At a glance you snippet seems to be plausible, so.
Or
are those bytes in positions 9 to 5?
a7
Are the bytes binary representation of the number or ASCII?
I see why you think you need a cast, maybe you do. But would not long long then be the type to choose?
a7
If I print the bytes like this:
Serial.println(dataRx[9]);
Serial.println(dataRx[8]);
Serial.println(dataRx[7]);
Serial.println(dataRx[6]);
Serial.println(dataRx[5]);
I'm getting these values:
46
90
167
201
36
Trying to get the number with the snipper in my first post, I get this value:
1520945444
If I swap the order I'm getting a negative number...
If you had printed in hex it would have made more sense.
2E
5A
A7
C9
24
and
1520945444 = 5AA7C924 hex
So the result is truncated to 4 bytes and the digits are reverse order in 2 byte chunks. Probably due to using the brain dead Intel ordering. (What? Me? have a preference in the big vs little endian war?)
YMMD :+1:
Ok. So now we know the result is truncated to 4 bytes etc... But how can I fix it? I'm still unsure what's happening here or what I do wrong.
Maybe a long long cast as suggested in post 4. With a long the 32 bit shift will be zero (you shifted all the bits out of the 32 bit long).
try
int64_t val = 0;
val += ((int64_t)dataRx[9]) << 32;
val += ((int64_t)dataRx[8]) << 24;
val += ((int64_t)dataRx[7]) << 16;
val += ((int64_t)dataRx[6]) << 8;
val += ((int64_t)dataRx[5]);
(int64 = long long)
Check GitHub - RobTillaart/printHelpers: Arduino library to help formatting data for printing for printing the data
It's something about the sign bits.
The below prints the right answer, you figure it out. I tried everything, so everything is still in there. Translation to Arduino-land an exercise for the reader.
It has nothgin to do with endianess.
# include <stdio.h>
// 24C9A75A2E and it means the value is 158002010670
unsigned char dataRx[10];
int main() {
  printf("Jello Whirled!\n\n");
  dataRx[9] = 0x2e;
  dataRx[8] = 0x5a;
  dataRx[7] = 0xa7;
  dataRx[6] = 0xc9;
  dataRx[5] = 0x24;
  long long val = 0;
  val |= ((unsigned long long) dataRx[5]) << 32;
  printf("1 val = %llx\n", val);
  val |= ((unsigned long long) dataRx[6]) << 24;
  printf("2 val = %llx\n", val);
  val |= ((unsigned long long) dataRx[7]) << 16;
  printf("3 val = %llx\n", val);
  val |= ((unsigned long long) dataRx[8]) << 8;
  printf("4 val = %llx\n", val);
  val |= (unsigned long long) dataRx[9];
  printf("\n\n");
  printf("val = %lld\n", val);
  printf("val = %llx\n", val);
yields
Jello Whirled!
1 val = 2400000000
2 val = 24c9000000
3 val = 24c9a70000
4 val = 24c9a75a00
val = 158002010670
val = 24c9a75a2e
...Program finished with exit code 0
Press ENTER to exit console.
HTH, time for something else. A pill of some kind, probably. :expressionless:
a7
While I was banging away incompetently the way I will.
THX.
a7
Quite likely. Beware shifting signed integer types.
This helped, was in fact the last straw. Or oh I don't know, going mad trying stuff.
a7
I was not able to produce the correct answer without changing dataRx to unsigned.
But I am late, and it's getting tired, so I may be wrongly concluding it is necessary.
a7
@AKnuts
Can the 5 byte value be a negative value?
Does it have a sign bit?
@alto777
You're probably right, signed shift might cause trouble.
Below a variant that does not shift the received bytes but val
As val stays far from having a sign bit, there is no overflow.
int64_t
for (int i = 9; i >= 5; i--)
  val <<= 8;
  val += dataRx[i];
This works:
int64_t val = 0;
val += ((int64_t)dataRx[5]) << 32;
val += ((int64_t)dataRx[6]) << 24;
val += ((int64_t)dataRx[8]) << 8;
val += ((int64_t)dataRx[9]);
didn't work here, I'll try again later.
That works better with the bytes in the right order.
int64_t val = 0;
for (int i = 5; i <= 9; i++)
  val <<= 8;
  val += dataRx[i];
I had also changed to |= , my habit when it is more like bit twiddling than arithmetic. Unecessary.
But I did still need to make dataRx unsigned.
I am running these using the online C++ interpreter at https://www.onlinegdb.com.
a7
That did not work until I made dataRx unsigned.
What Arduino board are you running this on?
OK, I ran it on the ESP32 - could it be... yes, argh! I can break your code that works by making dataRx signed.
So, do we have:
UNO char is signed by default, it must be told unsigned.
ESP32 char is unsigned by default, making it signed causes some, um, excitement.
Learn something every day.
a7
The lesson to be learned? Always use int8_t, uint8_t, etc. Then you'll know signed / unsigned. Use char only for ASCII characters. Those are <= 127 so signed / unsigned doesn't matter.
