Converting a binary number to a 16bit hex for use with FastLED
Hi everyone, I am looking for some help. I am working on a POV device that can display text. I am using 16 WS281 LEDS and I am using FastLED library to control them. Currently I only need the LED to ever be off or white.
I have being looking at using 'Dot Factory' to output a font for me at 16 px high. This works great but only outputs a 16bit interger in hex format. This can be used as a bit mask to switch LEDs on or off. The problem I have is that I need a value for each colour of each LED.
I was wondering if someone could help me with a function that takes the values from Dot Factory and convert each 0 to 0x000000 and each 1 to 0xffffff so that I can use it with FastLED.
Hope this has made sense and thanks with any help you can point me in the direction of.
Cheers
Steve
It does not. An example of the data that "Dot Factory" (whatever that is) is sending, and how you want to use that data with FastLED would be essential.
Could you perhaps mean WS2811 or WS2812 (aka NeoPixel)? According to Adafruit, these aren’t suitable for POV because their refresh rate is too slow:
You might consider the APA102 (aka DotStart). Here’s a POV project I did with them:
Sorry my question did not make enough sense, apart from the issue of the slowness of the LED I will have another go.
For example, the output from dot factory for “A” is
const uint_8 arial_16ptBitmaps =
0x00, 0x00, 0x00, 0xE0, 0xFC, 0x1F, 0x03, 0x1F, 0xFC, 0xE0, 0x00, 0x00, 0x00,
0x60, 0x7C, 0x1F, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x1F, 0x7C, 0x60,
So I want a function to convert it to this.
const unsigned int array1 ={0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0xffffff,0xffffff,0xffffff,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0xffffff,0xffffff,0xffffff,0xffffff,0xffffff,0xffffff,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0xffffff,0xffffff,0xffffff,0xffffff,0xffffff,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0xffffff,0xffffff,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0xffffff,0xffffff,0xffffff,0xffffff,0xffffff,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0xffffff,0xffffff,0xffffff,0xffffff,0xffffff,0xffffff,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0xffffff,0xffffff,0xffffff,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0xffffff,0xffffff,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0xffffff,0xffffff,0xffffff,0xffffff,0xffffff,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0xffffff,0xffffff,0xffffff,0xffffff,0xffffff,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0xffffff,0xffffff,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0xffffff,0xffffff,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0xffffff,0xffffff,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0xffffff,0xffffff,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0xffffff,0xffffff,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0xffffff,0xffffff,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0xffffff,0xffffff,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0xffffff,0xffffff,0xffffff,0xffffff,0xffffff,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0xffffff,0xffffff,0xffffff,0xffffff,0xffffff,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0xffffff,0xffffff,0x000000,0x000000,0x000000,0x000000,0x000000}
To use it in this code
#include "FastLED.h"
#define LED_PIN     2
#define NUM_LEDS    16
#define BRIGHTNESS  64
#define DATA_PIN 2//7 = second hardware spi data
#define CLOCK_PIN 3//14 = second hardware spi clock
#define LED_TYPE    WS2812
#define COLOR_ORDER GRB
CRGB leds[NUM_LEDS];
int numberOfSlices = 12;
  delay(200);
        FastLED.addLeds<LED_TYPE, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
    FastLED.setBrightness(  BRIGHTNESS );
const unsigned int array1[] = { 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0xffffff, 0xffffff, 0xffffff, 0xffffff, 0x0ffffff, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0xffffff, 0xffffff, 0xffffff, 0xffffff, 0xffffff, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0xffffff, 0xffffff, 0xffffff, 0xffffff, 0xffffff, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0xffffff, 0xffffff, 0xffffff, 0xffffff, 0xffffff, 0xffffff, 0xffffff, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0xffffff, 0xffffff, 0xffffff, 0x000000, 0xffffff, 0xffffff, 0xffffff, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0xffffff, 0xffffff, 0xffffff, 0x000000, 0xffffff, 0xffffff, 0xffffff, 0x000000, 0x000000, 0x000000, 0x000000, 0xffffff, 0xffffff, 0xffffff, 0xffffff, 0x000000, 0xffffff, 0xffffff, 0xffffff, 0xffffff, 0x000000, 0x000000, 0x000000, 0xffffff, 0xffffff, 0xffffff, 0xffffff, 0xffffff, 0xffffff, 0xffffff, 0xffffff, 0xffffff, 0x000000, 0x000000, 0x000000, 0xffffff, 0xffffff, 0xffffff, 0xffffff, 0xffffff, 0xffffff, 0xffffff, 0xffffff, 0xffffff, 0x000000, 0x000000, 0xffffff, 0xffffff, 0xffffff, 0xffffff, 0x000000, 0x000000, 0x000000, 0xffffff, 0xffffff, 0xffffff, 0xffffff, 0x000000, 0xffffff, 0xffffff, 0xffffff, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0xffffff, 0xffffff, 0xffffff, 0x000000, 0xffffff, 0xffffff, 0xffffff, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0xffffff, 0xffffff, 0xffffff, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, 0x000000, }; //end of array
PoiSonic(2000,array1); //call method, with duration to show (2sec) and array name.
//PoiSonic(2000,array1);
void PoiSonic(unsigned long time, const unsigned int array[]){
unsigned long currentTime = millis();
 while (millis()< currentTime + (time)) {
int f= numberOfSlices;
int z; //a counter
int j=NUM_LEDS;
    for (int x=0;x<f;x++){
     for(z=NUM_LEDS;z>0;z--){
       leds[z-1]=array[x+((j-z)*f)];}
     FastLED.show();
     delayMicroseconds(3000); //may need to increase / decrease depending on spin rate
    delayMicroseconds(400000); //may need to increase / decrease depending on spin rate
Hope this makes more sense.
Thanks for taking the time to read this.
It does not. That function sucks. It wastes an enormous amount of memory.
Rewrite the function, paying attention to memory usage (variable types), and make it use the data that you have. It is NOT that difficult.
Every value in your array is either 0 or 255. Every bit in the original array is either 0 or 1. There is a one-to-one relationship between the bits in the original array and the byte sized value in the second array (that are stored in containers twice as big as needed).
That's a waste of space duplicating the data, not just because you are using a type that is twice as big as needed.
One way to make it more memory efficient is to first decide how many bits per pixel (N) you want to represent the color (1, 2, 4, or 8 ). Thus, each pixel can be one of 2^N colors (including one entry for pixel=dark). You can then pack 8, 4, 2, or 1 pixels per byte. I did my project on a 32-bit machine, so I packed them into 32-bit words. Each group of N pixels is then used to index into a color pallet array. You pull the appropriate 24-bit color (in the form of a 32-bit word) from the array for each pixel.
