Converting a byte to an int
Evening all,
I'm currently working on a MQTT project using the Huzzah ESP2886.
I can subscribe and publish to feeds using PubSubClient, but am having a little trouble with a byte.
My code grabs any changes to a feed as a byte*. Now I can print that byte to the serial one character at a time - fine. But I want to use the byte to effect changes in my project. For example if my byte has the value '50' I want to convert the byte to a integer so that I can switch something on at a specific threshold.
I've googled around and am having trouble in finding a solution that works without an error message.
Here's my current code that prints out each character to the serial.
Thanks for your help!
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  for (int i = 0; i < length; i++) {
    Serial.print((char)payload[i]);
llewmihs:
Evening all,
  Serial.print("] ");
the function is bringing in a pointer to a byte:
byte* payload
one must de-reference the pointer to get the pointee:
byte myByte = *payload;
reads myByte = the value pointed to by payload
Thanks,
That's very useful - a second question. The data stored in the byte payload may be a string of text, e.g. 'hello'.
When I print the byte, instead of 'hello' i get : 104.
My code is now looking like this:
    Serial.println(myByte);
So I'm still unsure of how to then say compare it to a char in an if statement.
I want to do something like:
int choice = 50;
if (payload == text) {
//do something
else{
//do something different
'h' == 0x68 == 104
If you can fit "hello" into a single byte, you've managed something truly remarkable.
The function is returning a pointer to an array of bytes, rather than chars, because the payload is not limited to text. If you KNOW that the payload is text, add a NULL to the array pointed to, at the position defined by length, and then treat payload as though it was a NULL terminated character array (aka a string). You might need to lie to other functions, by using a cast.
PaulS:
The function is returning expecting a pointer to an array of bytes, rather than chars, because the payload is not limited to text. If you KNOW that the payload is text, add a NULL to the array pointed to, at the position defined by length, and then treat payload as though it was a NULL terminated character array (aka a string). You might need to lie to other functions, by using a cast.
instead of:
you have to write:
if (strcmp(payload, text) == 0) {
/Joe
BulldogLowell:
Actually, neither one of us is right. The function is called with...
you have to write:
Actually, that won't compile, since strcmp expects pointers to chars.
if(strcmp((char *)payload, "whatYouWantToCompareTo") == 0)
