Converting a double to a unsigned char?
Hi.
I'm pretty new to all this. But I'm using 2 different libraries. The output from my sensor is a double and then I'm trying to send this value from my sensor to bluetooth device. But the bluetooth device require a usigned char?
My value could be something like this:
double sensorValue = 22.22
And then I would like to use the value of "sensorValue" like this:
ble_write(sensorValue);
But that's not possible.
I looked into the library and it tells me that it's a unsigned char:
void ble_write(unsigned char data);
So how can I "send" this value from my sensor to my bluetooth device?
celfa:
Hi.
OLD_THREAD_HERE
Doesn't the library support a smart function that can send an array (print(), maybe?)?
mrsummitville:
OLD_THREAD_HERE
I've already tried everything mentioned there.
PaulS:
Maybe. But I'm not sure. The only to thing I can see is this:
void ble_write_bytes(unsigned char *data, unsigned char len);
This is my complete code:
#include <SPI.h>
#include <EEPROM.h>
#include <boards.h>
#include <RBL_nRF8001.h>
#include <Wire.h>
#include <Adafruit_MLX90614.h>
Adafruit_MLX90614 mlx = Adafruit_MLX90614();
  // Init. and start BLE library.
  ble_begin();
  // Enable serial debug
  Serial.begin(57600);
  mlx.begin();
unsigned char buf[16] = {0};
unsigned char len = 0;
  Serial.print("Ambient = "); Serial.print(mlx.readAmbientTempC());
  Serial.print("\tObject = "); Serial.print(mlx.readObjectTempC());
  ble_write(mlx.readObjectTempC());
  ble_do_events();
The serial part works fine, but my value received through bluetooth is just empty.
So:
char buff[10];
float likeDuck = 3.14159;
dtostrf(likeDuck, 8, 4, buff);
ble_write_bytes((unsigned char *)buff, strlen(buff));
Well, mlx.readObjectTempC() most likely does not return an unsigned char, so pretending that it does and being surprised when it doesn't is silly.
PaulS:
So:
char buff[10];
Thanks for your reply :slight_smile: I appreciate that. But when I'm trying to do this, I got the following error: "expected constructor, destructor, or type conversion before '(' token" regarding this line:
Yeah, I know that. Trust me, I've tried many different things. It was just a silly try from a newbie to illustrate what I was trying to do.
My mistake! I placed dtostrf outside my loop! Wooops. Sorry.
Thank you! Now it works like a charm!
