Converting a HC-SRO4 Dstance Measurement into an Analog Output
Hi
I was wondering if anyone could help me. I'm trying to use a HC-SRO4 ultransonic sensor to measure liquid level and use the readings as an analog input into a PLC. Can anyone suggest how I may be able to do this? Im not a programmer so my coding skills are quite basic.
Many thanks
John Q
Hi!
Distance measurement works by computing the time difference between sending and receiving a pulse. Both signals are digital (LOW or HIGH). It is not possible to do this with just reading an analog pin.
It is possible to connect an arduino to the HC-SR04 and convert the distance to a analog value with the arduino. Then this value is send to the plc.
Use an MaxSonar from Maxbotix instead - some (all?) have an analogue output, in addition to serial and PWM outputs.
Hi JackStardust,
Can you please help me how to do that?
Best regards
/MaverickRF
This post is very similar.
