Converting a string of times in vb
I have my Arduino sending 8 different times in a string to visual basic the times are in milliseconds but I want to convert to seconds to display them what's the best why to do this I was using time / 1000.0, 3 in the Arduino when I was sending them individually to the serial monitor but I can't get this to work when I send them in a string it always just displays a 3
does the serial mointor display what you expect? give an example
post the VB code?
        Dim timeString() As String
        timeString = myData.Split(New Char() {","c})
        reacL.Text = timeString(0)
        sixtyL.Text = timeString(1)
        mphL.Text = timeString(2)
        etL.Text = timeString(3)
        reacR.Text = timeString(4)
        sixtyR.Text = timeString(5)
        mphR.Text = timeString(6)
        etR.Text = timeString(7)/code]
I don't have all the VB code with me this is what I'm using now the mydata is coming in with a string of 8 times in milliseconds and I need to convert to Seconds
could you give an example of myData?
your StringSplit looks OK, e.g.
        Dim s As String = "data1,data2,data3"
        Dim words As String() = s.Split(New Char() {","c})
        Dim word As String
        For Each word In words
            Console.WriteLine(word)
        Next
gives
data1
data2
data3
Have you considered to print the individual times as seconds from your Arduino code?
You don't have to collect it in a String as you did in your other thread.
Serial.print(time1/1000, 3);
Serial.print(",");
Serial.print(time2/1000, 3);
Your PC will not notice the difference.
The mydata is coming in like 2435,2654,6545,3233,4553,3214,3212,2533,
They are millisecond from a timer everything is working and display right but I need to change to seconds
I was using serialprint(data1 / 1000.0, 3)
In the Arduino and printing each data separate but when I started using the vb and I tried to convert all the data then put it in the string and send to vb but all it would send was a 3 so I changed it back to just send the milliseconds
are you looking for output along the lines of
       Dim s As String = "2435,2654,6545,3233,4553,3214,3212,2533"
        Dim word As String
            Console.WriteLine(FormatNumber(word / 1000.0, 2))
        Next
gives
2.44
2.65
6.55
3.23
4.55
3.21
3.21
2.53
No I didn’t try that I will try that this afternoon when I print individual they would convert and sent
Also is there any way to other data to the vb using the same serial port maybe a different string and vb be able to tell the difference like I have a text box that all my serial data is printed to I can send serialprintln(“test) then my data and it come through on my text box
Test
23,34,45,43,32,11,56,83,
They were sent over at different time the test first then my data
And when it puts my data in the appropriate box my first box shows
Test
23
Can I make it ignore the text and just show my data or do I need to have everything print at once and split the text out in my string also
if you are transmitting different types of data at random you require a protocol, e.g. each line could start with a string indicating the data type
time,2435,2654,6545,3233,4553,3214,3212,2533
test,23,34,45,43,32,11,56,83
use String.Split examine the first element to determine the data type e.g.
        Dim s As String = "time,2435,2654,6545,3233,4553,3214,3212,2533"
        If (String.Compare(words(0), "time") = 0) Then
            For i As Integer = 1 To words.Length - 1
                Console.WriteLine(FormatNumber(words(i) / 1000.0, 2))
            Next
        End If
Yes that’s what I’m looking for
Though out my Arduino program it will print Stuff to let me know what is going on like it will print go left or jump left go right or jump right I want all that to stay in my text box but pull my times to the appropriate box to display so would I just need to indicate my times with the protocol to be pulled from the text box and the rest will just print to the box
Yoy could print times to one textbox and the other output to a different textbox
I would like to do that but I no clue on how to or even where to start to right the code
horace:
        Dim word As String
        Next
gives
2.44
2.65
6.55
3.23
4.55
3.21
3.21
2.53
i tried this but it was giving me System.InvalidCastException
HResult=0x80004002
Message=Conversion from string “” to type ‘Double’ is not valid.
Source=Microsoft.VisualBasic
this was my code
Imports System.IO.Ports
Public Class Form1
    Dim comPORT As String
    Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
        comPORT = ""
        For Each sp As String In My.Computer.Ports.SerialPortNames
            comPORT_comboBox.Items.Add(sp)
        Next
    End Sub
    Private Sub comPORT_comboBox_SelectedIndexChanged(sender As Object, e As EventArgs) Handles comPORT_comboBox.SelectedIndexChanged
        If (comPORT_comboBox.SelectedItem <> "") Then
            comPORT = comPORT_comboBox.SelectedItem
        End If
    End Sub
    Private Sub connect_Btn_Click(sender As Object, e As EventArgs) Handles connect_Btn.Click
        If (connect_Btn.Text = "Connect") Then
            If (comPORT <> "") Then
                SerialPort1.Close()
                SerialPort1.PortName = comPORT
                SerialPort1.BaudRate = 115200
                SerialPort1.DataBits = 8
                SerialPort1.Parity = Parity.None
                SerialPort1.StopBits = StopBits.One
                SerialPort1.Handshake = Handshake.None
                SerialPort1.Encoding = System.Text.Encoding.Default
                SerialPort1.ReadTimeout = 10000
                SerialPort1.Open()
                connect_Btn.Text = "Dis-connect"
            Else
                MsgBox("Select a COM Port First")
            End If
        Else
            SerialPort1.Close()
        End If
    End Sub
    Private Sub BtnStart_Click(sender As Object, e As EventArgs) Handles BtnStart.Click
        If BtnIG.Checked = True Then
            SerialPort1.Write("I")
            TextBox1.Text = ""
        ElseIf BtnPT.Checked = True Then
            SerialPort1.Write("P")
            TextBox1.Text = ""
        ElseIf BtnST.Checked = True Then
            SerialPort1.Write("S")
            TextBox1.Text = ""
        End If
    End Sub
    Private Sub CheckBox1_CheckedChanged(sender As Object, e As EventArgs) Handles ldisp.CheckedChanged
        If ldisp.Checked Then
            SerialPort1.Write("ld")
        Else
            SerialPort1.Write("LD")
        End If
    End Sub
    Private Sub rdisp_CheckedChanged(sender As Object, e As EventArgs) Handles rdisp.CheckedChanged
        If rdisp.Checked Then
            SerialPort1.Write("rd")
        Else
            SerialPort1.Write("RD")
        End If
    End Sub
    Private Sub DataReceived(ByVal sender As Object, ByVal e As SerialDataReceivedEventArgs) Handles SerialPort1.DataReceived
        Try
            Dim mydata As String
            mydata = SerialPort1.ReadLine()
            If TextBox1.InvokeRequired Then
                TextBox1.Invoke(DirectCast(Sub() TextBox1.Text &= mydata, MethodInvoker))
            Else
            End If
        Catch ex As Exception
            MessageBox.Show(ex.Message)
        End Try
    End Sub
    Private Sub Timer1_Tick(sender As Object, e As EventArgs) Handles Timer1.Tick
        Dim s As String
        s = TextBox1.Text + "," + "," + "," + "," + "," + "," + "," + "," + ""
        Dim timeStrings() As String = s.Split(New Char() {","c})
        Dim timeString As String
        For Each timeString In timeStrings
            Console.WriteLine(FormatNumber(timeString / 1000.0, 3))
        Next
    End Sub
End Class
you are probably using FormatNumber() to convert a String to Double which does not contant valid numeric data (in this case an empty string "")
try using Double.TryParse() which will tell you if the conversion fails, e.g.
            For i As Integer = 0 To words.Length - 1
                Dim value As Double
                If Double.TryParse(words(i), value) Then
                Else
                    Console.WriteLine("Error! string '" + words(i) + "' is not a Double")
                End If
            Next
        End If
gives
Error! string 'time' is not a Double
2.44
2.65
6.55
3.23
4.55
3.21
3.21
2.53
attempting to convert the string time to a double fails and displays the error message
any reason why you analyse your data in a timer event handler rather than the serial data received event handler? also note you should not directly manipulate GUI components (such as a TextBox) in the serial event handler - it is not thread safe - use a delagate
