I didn't think this would be any problem but i can't seem to find the information i need, and yes I've looked and looked. I am working with an esp8266-12n, hopefully this is an ok place to ask about this as its more a math problem than a specific board problem i'm having. The control board went bad in the oven, a new one was $150, i decided i would save some $$ (at the expense of over a week now of planning, soldering, writing code).
Here is what i have physically, 5V ---> NTC thermistor ---> A0(through a 4051 multiplexer) ---> 2K Resistor ---> GND
A0 on this board is 0 - 3.3v, 0-1024
Here is a chart with the resistance to temp relationship of the thermistor,
I am using a 2k pot at the moment to simulate the thermistor. With the pot set to 1K, i get 1024 (and yes it just hits 1024 right at 1k), with it set to 2k, i get 764. So what i am trying to figure out is how to convert the value of A0 to the actual temperature.
Here is the code i have so far, it seems to be doing what i want it to do, with the exception of the temperature conversion issue. I am still quite the noob, started toying with a R3 Mega less than a month ago, no previous experience with microcontrollers, and a basic understanding of components (transistor/capacitor/diode/resistor etc.. I'm sure my code is horrible but it works lol. I would appreciate any assistance with this.
LiquidCrystal_I2C lcd(0x27, 16, 2);
#define sA D5 // 4051 Select Pin A
#define sB D6 // 4051 Select Pin B
#define sC D7 // 4051 Select Pin C
#define inputPin A0
#define bakePin D0 // bake transistor pin
#define broilPin D8 // broil transistor pin
int debounce = 750; // delay for button debounce
int lcdRefresh = 500; // how many ms between writes to lcd
bool bakeState = 0; // used to keep track of the state of the bake transistor
bool broilState = 0; // used to keep track of the state of the broil transistor
bool bakeEnabled = 0; // flips from 1 to 0 with button press, enables tempControl() to turn on transistors for element relay's
bool broilEnabled = 0; // flips from 1 to 0 with button press, enables tempControl() to turn on transistors for element relay's
bool tempHigh = 0; // used to keep off loop from running over and over
unsigned long bakeButtonPrevMillis = 0;
unsigned long broilButtonPrevMillis = 0;
unsigned long lcdWriteMillis = 0;
int tempDesired = 0; // holds desired temp
int temp = 0; // holds temp reading
lcd.init(); // initializing the LCD
lcd.backlight(); // Enable or Turn On the backlight
pinMode(sA, OUTPUT);
pinMode(sB, OUTPUT);
pinMode(sC, OUTPUT);
pinMode(bakePin, OUTPUT);
pinMode(broilPin, OUTPUT);
readBakeButton(); // see if bake button has been pressed
readBroilButton(); // see if broil button has been pressed
tempControl(); // control the temp if bakeEnabled or broilEnabled == 1
if(millis() - lcdWriteMillis >= lcdRefresh){ // write to the lcd at "lcdRefresh" interval
writeLCD();
void tempControl() {
readTempPot(); // read the temp set pot
readTempSensor(); // read the ntc thermistor
if (bakeEnabled == 1 && (temp <= tempDesired - 5) && bakeState != 1) { // if bake is enabled, and temp is 5* lower than desired temp, and bake is not already on, run bakeOn()
tempHigh = 0;
bakeOn();
bakeState = 1;
if (bakeEnabled == 1 && temp >= tempDesired + 5 && tempHigh != 1) { // if bake is enabled, and temp is 5* higher than desired temp, and tempHigh is not already 1, run bakeOff()
tempHigh = 1;
bakeOff();
bakeState = 0;
if (bakeEnabled == 0 && bakeState != 0){ // if bake is not enabled and bakeState is not already 0, run bakeOff()
bakeOff();
bakeState = 0;
if (broilEnabled == 1 && (temp <= tempDesired - 5) && broilState != 1) { // same as above but for broil
tempHigh = 0;
broilOn();
broilState = 1;
if (broilEnabled == 1 && temp >= tempDesired + 5 && tempHigh != 1) {
tempHigh = 1;
broilOff();
broilState = 0;
if (broilEnabled == 0 && broilState != 0){
broilOff();
broilState = 0;
void readBakeButton() {
int a;
digitalWrite(sA, HIGH); // select the correct channel of the 4051 mulitplexer to read the bake button
digitalWrite(sB, HIGH);
digitalWrite(sC, LOW);
a = analogRead(inputPin); // read A0 and place value into int "a"
//Serial.println(a);
//delay(500);
if (a <= 100 && (millis() - bakeButtonPrevMillis) >= debounce){ // if a is less than 100, assume bake button has been pressed
if (bakeEnabled == 0){ // if bake is not already enabled, enable it
bakeEnabled = 1;
Serial.println("Bake ON (from readBakeButton() )");
bakeButtonPrevMillis = millis();
else {
bakeEnabled = 0; // else disable bake
Serial.println("Bake OFF (from readBakeButton() )");
void readBroilButton() { // same as readBakeButton()
int a;
digitalWrite(sA, LOW);
digitalWrite(sB, LOW);
digitalWrite(sC, HIGH);
//delay(500);
if (a <= 100 && (millis() - broilButtonPrevMillis) >= debounce){
if (broilEnabled == 0){
broilEnabled = 1;
Serial.println("Broil ON (from readBroilButton() )");
broilButtonPrevMillis = millis();
else {
broilEnabled = 0;
Serial.println("Broil OFF (from readBroilButton() )");
void bakeOn() {
Serial.println("Bake ON");
digitalWrite(bakePin, HIGH);
void broilOn() {
Serial.println("Broil ON");
digitalWrite(broilPin, HIGH);
void bakeOff() {
Serial.println("Bake OFF");
digitalWrite(bakePin, LOW);
void broilOff() {
Serial.println("Broil OFF");
digitalWrite(broilPin, LOW);
void readTempPot() {
tempDesired = analogRead(inputPin);
void readTempSensor() {
temp = analogRead(inputPin); // need to figure out how to convert this value to actual tempurature in *F
void writeLCD() {
lcd.setCursor(0, 0);
lcd.print("S: ");
lcd.print(tempDesired);
lcd.print(" ");
lcd.print("A: ");
lcd.print(temp);
lcd.setCursor(0, 1);
lcd.print("Bake:");
if(bakeEnabled == 1){
lcd.print("* ");
if(bakeEnabled != 1){
lcd.print(" ");
lcd.print("Broil:");
if(broilEnabled == 1){
lcd.print("*");
if(broilEnabled != 1){
lcd.print(" ");
lcdWriteMillis = millis();
